Trust me; go with 1 3/4" dia. and not the 1 7/8" if you want to be in front at the end of the 1/4 mile or the end of the block!
If I had to guess and from my experience I would say 20+ hp and/or 2 MPH+ increase in the 1/4 mile. I may have gotten more (custom fabrication/installation ) so I'm also going from what I have read. Oh, and I'm using the cheap stock (430 hp) mufflers and the car is silent at cruise with no cats.
The Kooks Headers gain ~25 rwhp untuned and after tuning, usually another 10 rwhp. Go with the 1 7/8" and the LS3 does great with these. Just installed a set yesterday and gained +44 rwhp and +38 ft-lbs on a 2008 Corvette with a Vararam. With the 1 7/8" Headers, at 2000 rpm gains are 20 ft-lbs.
My "Real World" results using a "stock" OEM paper filter and housing converted to a home made CAI setup, 1 3/4" headers and an "out of the box" 93 Predator tune I think would kick A$$ on the above result if it was on a GS coupe with an A6 like mine; Check the 1/4 mile GS bolt-on listing, I"m the big dog at the moment= 11.52 @ 121.89 MPH running on the stock runcraps to booth!
Oh, and the second place guy (410 rwhp with a A6 & NPP) is 4 tenths and over 3 MPH slower using the same but good stuff i.e. professional tune, aftermarket Vararam CAl, and 1 7/8" headers I think. Just Check it out. I rest my case!
You guys are arguing over an 1/8 of an inch, I own a company that sells tubing (Kook's even buys from us sometimes)we see all kinds of variance in what is marked and what it actually measures. What I have learned about these cars in the past week is anything is better than stock!
Yes, the 1 3/4 may pull better down low on a stocker but what about if there are mods to be made in the future? My GS just dynoed 437 rwhp after the cam install with a totally stock exhaust. I was shocked. I bet I see close to a 60 hp rw gain when I install the 1-7/8 headers and 3" exhaust from a zo6 (yeah I see that it necks down a bit, I just want some stock quiet).
If all you are going to do is some light bolt ons consider 1-3/4 any major mods buy em once and get 1-7/8.
Glad you bought up that the tube diameter is not always what it is suppose to be because mine are actually "smaller" (1.60" I.D. if I remember correctly) than 1 3/4"= 1.75" I.D.
1 5/8"= 1.625"
PS: My tubes are shorter than most and the lengths vary also but still larger in diameter than the LS3 heads exhaust ports i.e. the tubes cover the exhaust ports with no interference/restrictions.
1 5/8"= 1.625"
also.
That would be correct as tubing is measured by it's outside diameter. In reality you could have a set of 1-7/8" headers made with 16 ga (.065") tubing vs a set of 1.75" headers made with 18 ga tubing (.050") and basically have the same thing.
Glad you reminded me how "tubing" is measured, pipe up to 6" if I remember correctly is measured I.D. But according to the specs that are advertised the wall thickness on mine is .059".
It probably doesn't make a beans hill of difference. Either way you're going to have a gain!! With my 08 auto I picked up 39hp 27tq with 1 7/8" without cats
Those are impressive results. "Bigger is better" seems to be the current mentality but is not always the case. You've obviously stumbled on a sweet-spot for a bolt-on combination. I don't think most people would even consider 1-5/8" headers these days, but that used to be the most common performance header size used on the 1st gen small block motors.
Hey, got Billy boat fusion in back, hurricane induction, 170 degree thermo, nology wires, spoke with Billy boat and he said to run long tube headers no highflow cats in Mi. and their crossover, "may have to reflash computer", [predator], their headers and X pipe to provide 45+hp, dash may say codes (reflash), not sure from BB.
Any ideas out there??????
