Borla Install
Old Mar 25, 2012 | 05:48 PM
Randyg55's Avatar
Randyg55
Default Borla Install
Ok so my new borla stingers are going to be here tomorrow. Any advice on the install by the pros? Its a cat back system 2006 m6... How high do I need to get it? Pretty geeked as its my first mod.
Thanks for any help..
Old Mar 25, 2012 | 06:12 PM
ClemsonT/A's Avatar
ClemsonT/A
Back the car up on ramps. Spray bolts with PB Blaster. Open beer. Drink beer. Undo bolts and remove old exhaust. Open another beer. Drink beer. Put on new exhaust. Open beer. Crank up the car and smile.
Old Mar 25, 2012 | 06:19 PM
hangtime204's Avatar
hangtime204
Might be easier with the rear sway bar loose at the end links, as well as loosen the clamps at the axle back to the xpipe, and then loosen the xpipe to converter bolts as you may not have enough room to pull the mufflers far enough back.
Old Mar 25, 2012 | 06:43 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Should be an easy install, mine were. The sound will gradually improve over the first 600 or so miles if you like them loud and deep!
Old Mar 25, 2012 | 07:08 PM
Randyg55's Avatar
Randyg55
Perfect !! Except I'm a crown royal black drinker!!
Old Mar 25, 2012 | 07:10 PM
Randyg55's Avatar
Randyg55
Thanks for the tips. I was really worried about the drone but what I've been told it is nill.
To Borla Install
