bleeding abs unit
Old Mar 26, 2012 | 06:52 PM
REVAK's Avatar
REVAK
Default bleeding abs unit
Other than a Tech II , are there any other scanners that will perform the abs bleed procedure for the abs unit ?
Old Mar 26, 2012 | 07:12 PM
VettFanatic123's Avatar
VettFanatic123
not sure about your question , but i just redid a z06 and all my brake lines were open and all i had to do was bleed the calipers like normal no issues at all i hope this helps
Old Mar 26, 2012 | 07:50 PM
RicK T's Avatar
RicK T
Can't answer your question.
Just providing thoughts on the need to bleed the ABS unit and options.
http://forums.corvetteforum.com/c6-t...id-change.html
Old Mar 26, 2012 | 08:45 PM
Bill Dearborn's Avatar
Bill Dearborn
Autoenginuity will do that and issue a lot of the other commands the Tech 2 can issue.
Bill
Old Mar 26, 2012 | 11:29 PM
JCtx's Avatar
JCtx
Best way to avoid having to do that is to replace brake fluid regularly. I do it every year to year and a half, eliminating the need to push the ABS piston. But if you wait until fluid is filthy, I'd want it done.
Hey Bill, how much that 'autoenginuity' cable and software? Must be similar to the GS-911 I have to use on my BMW bike. It's just a 'smart' cable, and you need a laptop with the appropriate software.
Old Mar 27, 2012 | 03:46 AM
jft69z's Avatar
jft69z
Snap On Modis will do it.
To bleeding abs unit
