Need help.... What is this part....
Old Mar 30, 2012 | 10:36 PM
David90's Avatar
David90
Default Need help.... What is this part....
Can someone help me out, I was just getting home when i stepped on my clutch i felt something loose, I looked under and I found this piece. I don't know what it is, was wondering if anyone has ever had this issue with this. I drive a 6 Speed 2006 Base C6
Old Mar 30, 2012 | 10:50 PM
lownslo's Avatar
lownslo
Appears to be a broken clutch spring
Old Mar 30, 2012 | 11:08 PM
torquetube's Avatar
torquetube
Yes, that's a broken clutch pedal assist spring. It's not uncommon for the to fail, at least on the first few model years. It doesn't seem like you hear about them failing as often now.
Replacements are not expensive. See numerous threads on the subject.
Old Mar 30, 2012 | 11:12 PM
David90's Avatar
David90
Thanks for the help, started doing some more research and seems like some people actually remove it.... Thanks again!
To Need help.... What is this part....
