High Zinc oil, is it ok for a Vette?
Are some of these newer oils with high zinc content ok for a car with cats and O2 sensors? Amsoil dealer can't tell me for sure. Thanks.
Received 2,062 Likes
1000-1200ppm is about as high as I'd go. JMO
It's probably good to get second opinions. Too many Amsoil dealers are just there for the money and really don't know the products.
High zinc , good for your engine , possibly not good for your cat. conv. I personally use the higher zinc oils , cat's are cheaper than motors . I don't think the o2's are affected by the zinc. The o2's don't like lead.
Premium Supporting Vendor
There are several issues here and one of the most important for cars under warranty is that high ZDDP oils do not comply with the owner's manual (though they provide better protection).
Sound like the dealer you are speaking with is not very knowledgeable.
As an FYI, I'm happy to sell to all forum members at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. For those interested, please drop me a PM.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Suggest you read this whole thread, particularly my posts #28 and #35.
Sorry - completely left the link to the thread I suggest you read out of the above post.
Here you go:
http://forums.corvetteforum.com/c6-z...n-content.html
I think the consensus on that thread is that the engine is much more expensive than the cats, so if you track, go against the owner's manual, use a high ZDDP oil, and worry about the cats later. Can always buy used ones off Ebay from guys like me that eventually just take the cats off the car.
If I were in your shoes, I'd use the ZROD 10w30 - noting it doesn't meet either AMSOIL or GM's recommendations. I use the Dominator Racing 10w30 in mine (stock LS6 internals with headers, no cats, no muffler, running a race tune and race fuel, and increased rev limit).
The primary difference is that the Dominator doesn't have detergents or dispersants and I change my oil at about every 500 miles (four track days or so). I probably could go longer. The ZROD has no where near the detergents/dispersants of the Signature Series line but has some (but for a track car that is good as there is more basestock anti-wear additives which is what you want). AMSOIL rates the ZROD for about 3-5k oil change intervals.
Here you go:
Here you go:
Here you go:
My pleasure.
I just started using Royal Purple HPS (High Performance Street) Has higher ZDDP levels and still has the detergents of a street oil.
Mark
Mark
I don't see much of the European stuff in my area but I do see the Royal Purple at the local store. I've used Amsoil in all my stuff for years so I'll probably stick with it for now. Thanks.
Mark
I am not sure what oil you are talking about but most oils sold in the US have had the zinc removed from it or it is very low! I run Brad Penn oil in my 530CI cadillac on my airboat because it is has a flat tappet cam and without the zinc I will wear the lobs off the cam.
The AMSOIL Z-ROD has phosphorus 1320 ppm and zinc 1440 ppm (API SN spec is 800 ppm phosphorus). Mobil 1 0w40 has phosphorus 1000 ppm, zinc 1100 ppm. Not sure of the RP HPS.
As a suggestion for your airboat:
AMSOIL SAE 10w40 Formula 4-Stroke Marine Synthetic Motor Oil
AMSOIL SAE 10w30 Formula 4-Stroke Marine Synthetic Motor Oil
These marine motor oils are high ZDDP as they aren't limited by API specs, but they have the proper anti-rust additives you want in a marine motor oil as opposed to an automotive engine oil.
I would like to find out if the new low E diesel oils are low on zinc as well. My older truck would be better off with good oil. I don't use syn in it as it's not as important in a diesel. May have to start now. I know low E can't be a good thing. Most guys on the Duramax forum use Delo or Delvac. Any advice subdriver?
The overall impact is very similar to what has happened with automotive oils. Sort of a dual edged sword for the market. The minimum standards have been raised, thus those that go for the absoluate cheapest oils on the market are getting a better oil with the newer standards. Conversely, many limits imposed on the high end limit what the top end oils can do. The delta between the best and worst oils got smaller.
Though not all oil companies share all their oil specs, and many don't have CI-4 oils anymore, AMSOIL does promulgate the applicable specs and they do have both CI-4 and CJ-4 oils.
Their 15w40 CJ-4
- TBN: 10.4
- HTHS: 4.2 cSt
- 4-ball wear: 0.51mm (40 kgf, 75C, 1200 rpm, 1 hr)
Their 15w40 CI-4
- TBN: 12.1
- HTHS: 4.3 cSt
- 4-ball wear: 0.35mm (40 kgf, 75C, 1200 rpm, 1 hr)
I think the most telling is the 4-ball wear which is clearly better with the older spec oil, but the Total Base Number is higher with the old spec, as is the High Temp High Shear viscosity.
In my 07 RV which has a pre-07 Duramax I chose to run the older CI-4 spec 15w40. In my 08 GMC 3500 HD (recently sold) I ran the new spec CJ-4 15w40 as it had a diesel particulate filter. Would've been easier for me to buy and stock the same oil for both, but I want the best protection for the diesel in my RV (track tow vehicle).
FYI - AMSOIL does carry CJ-4 in 15w40, 5w40 and a cost effective (not long interval) 15w40, and the older CI-4 in 15w40 and 5w30.
AMSOIL Diesel Oils
