Does a ZR1 come stock with headers? If not, why not? Here is my point--- there must be SOME cons (as opposed to all pros) when it comes to headers vs. exhaust manifold. Possibly to actually keep the engine operating at a higher temp (though, obviously, not too hot) and/or to keep the engine from cooling down too fast when turned off in cold ambient air conditions? There MUST be some good reason to not have headers isn't there?
bean counters and emissions standards are my guess. The cats are moved further downstream which makes them less efficient.
I am thinking that it wouldn't be any more expensive for GM to put headers on ALL LS9s instead of an exhaust manifold. Don't see why that would cost any more if the ZR1 currently has an exhaust manifold setup unique to LS9.
You have to have room and the bean-counters have to approve it.
If the ZR1 didn't need them to reach the hp #'s that the execs desired or deemed appropriate, why would they bother? There also may be additional, not-so-obvious NVH, heat, or emissions issues, as others have noted.
Interestingly, the new 650hp GT500 uses typical cast-iron manifolds, while the new 5.0 Mustangs have a shorty "header" stock.
If you remove the heat shield from the manifold used on the Z06/LS9 you will find that it is actually a short tube header made from steel and individual tubes, far better than the mess in the above pic.
Long tube headers suffer from the lack of heat to bring the cats up to temp quickly and hold it there.
Current designs for optimum cat efficiency is to mount the cat right at the exhaust manifold flange. The newest 4 banger GM has the exhaust manifold cast as part of the head.
Thank you very much for that answer!! So, the LS7 and LS9 do, indeed, have short tube headers and the need for cat heat is the only reason they are not long tubes.
You can see the individual tubes from the inverted image
Mostly emissions and then packaging. You also have to look at durablity.
If you search for LS7 exhaust manifold in google images I'm sure you'll find a pic of the manifold showing the tubes.
On the dyno they perform just like a short tube header over the standard LS2/3 manifold. You wouldn't know it to look at them, but they do work.
Ive been wondering why no one makes longtube headers with heatshields. They'd look a lot more like stock and the average guy doing the visual inspection wouldn't know any better...
