Cruise control inop...
Old Apr 6, 2012 | 12:03 AM
bingo1105's Avatar
bingo1105
Default Cruise control inop...
My cruise control has been inoperative ever since I had a cam and gears installed on my MN6 Z51. I suspect something related to the tune, but my installer says that nothing related to cruise should have changed. My installer isn't exactly close by, so I've chosen to live with it rather than take it back... the car is running great otherwise, and I'm pleased with the results...
Here's my question... is it likely that a tune would be the culprit? I find it hard to believe that this is a coincidence, and if a re-tune would sort this out, that'd be a great excuse for a ported FAST 102.
Fuses are good, clutch position sensor is good according to my local dealership... is there anything else I should check?
Thanks in advance...
Old Apr 6, 2012 | 10:42 AM
marc8090's Avatar
marc8090
My first thoughts were clutch position switch and brake switch. You've already checked one, I would check the other. A common test is to hold the brake and/or clutch pedal all the way up and try to engage the cruise control. If it works it's one of those switches.
Old Apr 6, 2012 | 05:28 PM
bingo1105's Avatar
bingo1105
Tried pulling up on the pedals without success. Also tried disconnecting the negative battery terminal and made sure the taillights are functioning...
I received a PM from another forum member saying that an issue with his tune killed his cruise, so perhaps that's my issue after all. If there are any other 'simple' causes I should check, please let me know...
Old Apr 6, 2012 | 06:33 PM
VET4LES's Avatar
VET4LES
You checked the tail lights but what about the stop lights. If just one is out it can cause your problem.
To Cruise control inop...
