A6 hitting rev limiter WOT
Old Apr 8, 2012 | 08:26 PM
jpuli28's Avatar
jpuli28
Default A6 hitting rev limiter WOT
Doing some spirited driving on an empty road Ive noticed a couple times now Im hitting the rev limiter WOT while in S mode, but not using the paddles, this is from a roll on. I back off and resume normal driving and all is fine. I may have smelled something hot but when parked I could no longer find the scent.
I have a tune so maybe it just needs adjusting, am I not alone here?
Its an 07 with 41k...
Old Apr 8, 2012 | 08:56 PM
Red06Vette's Avatar
Red06Vette
jpuli28
Is traction control turned on or off?, If it's not turned off, trans will not shift with tires spinning.
Old Apr 8, 2012 | 10:30 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
If you are sure TC is off and its only in S and not drive, I would check what the shift points are set at. Maybe they are too high in S mode and with the delay in the shift it allows it to rev to the limiter.
Old Apr 8, 2012 | 10:40 PM
jpuli28's Avatar
jpuli28
TC was off on this event, the others I dont recall. I go into tuner this week for a tranny cooler coincidentally, hopefully its just the shift points.
Old Apr 9, 2012 | 12:02 AM
ChevyDave's Avatar
ChevyDave
There was another recently with this same problem... they havent answered yet their solution, but was leaning towards tune/shift points..
http://forums.corvetteforum.com/c6-c...post1580455948
Old Apr 9, 2012 | 12:47 AM
HOXXOH's Avatar
HOXXOH
Who did the tune and do you know what rpm you hit the limiter?
Old Apr 9, 2012 | 10:33 AM
jpuli28's Avatar
jpuli28
Local tuner/vendor. Idk but the engine was still spinning with no shift in site and I was just in the red.
Old Apr 9, 2012 | 10:44 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Default Different rear end ratio?
Make sure the rear end ratio of your car matches the rear end ratio of the transmission tune that was put in your car. If not, the rpm/speed values will not match and you can hit the rev limiter without satisfying those requirements.
Old Apr 9, 2012 | 10:47 AM
jpuli28's Avatar
jpuli28
Thats all good call, because I was running 305/30 in the rear with 275/35 up front causing the TC to activate at 120 and we fixed that. I dont think we readjusted when I put the 325s on.
Thanks to everyone btw
Old Apr 9, 2012 | 01:10 PM
HOXXOH's Avatar
HOXXOH
Good choice for a local guy, because he can scan and record the problem and make the adjustment. He'd be the first one to call for assistance.
To A6 hitting rev limiter WOT
