Whats safe timining for ls2
Old Apr 9, 2012 | 10:42 AM
5clubLS2's Avatar
5clubLS2
Default Whats safe timining for ls2
I have a feeling my tuner is not giving me the best tune I can get. I was thinking I could run a bit more timing with the E85 and cam, right now my tuner has me at 28-29, is this low?? I just thought we could be a bit more aggressive with timing at least 30 but I not sure, any help out there? Any experienced tuners, guys who have seen this setup before or who seen more compression? Any help will be appreciated
Old Apr 9, 2012 | 11:38 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Every car is different. What works for your car may not be enough for another. My car. for example, hates timing.
Old Apr 9, 2012 | 09:29 PM
taken19's Avatar
taken19
Track Junky
You may want to post in the tuning section as they may give you better answers. Generally, a tuner with add timing until he/she sees knock, then backs up one iteration.
Old Apr 10, 2012 | 01:04 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Yes and no.
Generally speaking--yes, that's the case. I found that my car like less timing and loads more fuel. The LS3 is very efficient and as such, does not respond well to lots of timing. I only run 21* during peak torque and 24* peak timing at 6000. I had a lot more timing in it to begin with but it seems the more I removed it, and the more fuel I threw at it, the better it responded.
It just goes to show that every car is different and the dyno is a really great tool to establish what your particular car really does and does not like.
Old Apr 10, 2012 | 01:20 PM
taken19's Avatar
taken19
Track Junky
Good insight. just goes to show you how little I know about tuning, lol.
Old Apr 10, 2012 | 01:25 PM
JUIC3D's Avatar
JUIC3D
You'll learn young grasshopper
Old Apr 10, 2012 | 02:22 PM
LEAVINU's Avatar
LEAVINU
What kindof power are you making with the cam and E85? Basic cam specs and compression?
My LS2 doesn't really respond to a ton of timing on 93 octane. We tried adding more and the power started to fall off.
JUIC3D's Avatar
JUIC3D
Damn, 30* seems like a ton of timing for an LS2
Old Apr 10, 2012 | 02:30 PM
Shifter6's Avatar
Shifter6
there is no set number. All LS engines have a fairly effecient combustion chamber design an dont like alot of timing. I remember when we tuned windsor Fords with factory heads, you would see power increases up to 38* BTDC peak timing, ha. most LS engines seem to be happy in the mid high twentys.
If you proceede carefully there is no reason you cant try trial and error on the dyno. Add a little timing until it pings or the power goes flat. My tuner can hear pinging long before the KR kicks in.
Good luck
Old Apr 10, 2012 | 04:21 PM
5clubLS2's Avatar
5clubLS2
My cam spec and current compression is in the title, I making 455-470wrhp right now, I havent dyno since the new tune and before then was putting down 456wrhp with e85 and 102 fast no tune. We had to cancel dyno day this past weekend or I would have new final numbers. The car feels so much tougher after I got it back from the tuner, I would say easily a 10-15 hp gain, but a lot of guys here in the city has commented that it seems my timing numbers were low for e85 and cam, so I thought I would see what you guys(expert corvette guys) knew about it. Thanks @Taken19 I did post this in the wrong section. Thanks guys for your help.
Old Apr 10, 2012 | 04:32 PM
JUIC3D's Avatar
JUIC3D
For starters, your title says nothing about your cam spec etc. It just says "Whats safe timining for ls2"
Second, I'd bet the 'guys in the city' are old school and not familiar with how the 4th generation of the Chevy small block functions with regards to timing requirements.
As I said before, every motor is different and that's what makes the dyno so important. I can tell you that you won't feel a 10-15hp gain on a 460hp motor and if you are feeling a difference in the previous tune, the hp/tq gain will be higher than 10-15whp. Changes in the air quality alone can account for much more than that so if you ran the car in the heat of the day, and then at night, it would feel like it's making more power.
Old Apr 10, 2012 | 05:29 PM
5clubLS2's Avatar
5clubLS2
232/238 620/612 122+4, sorry I thought I listed that already. But no I drove it all in the same temp, its 60 degrees here so not much heat heat, actually it was cooler out when i dropped it off than when i picked it up, of course when your car is cooler it seems faster but this is just new power. I dont know if its in my head but I know my car well and like you said maybe its just more than 10-15hp gain but I was trying to be realistic in thinking a tune would give anymore than that.
Old Apr 10, 2012 | 06:09 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Yea but he is running E85. The GM race tune has LS2's running about the same on race fuel.
You know I hate to be the one to say this, not really This is where a load bearing dyno comes into play. You can actually what your torque numbers and be able to figure out where you make the most torque at and go from there. The is no replacing the proper tools and that includes a proper dyno.
Old Apr 10, 2012 | 06:11 PM
Zip Corvettes
Every car is different. I just ran a CTSV with the LSA and it loved fuel on the top end, more than where I would like to see it but it's hard to argue when it keeps making more power while your feeding in the fuel.
Old Apr 11, 2012 | 02:29 AM
lilmiller74's Avatar
lilmiller74
I have an ls2 with un-milled and un-ported ls3 heads and a small cam and it loves timing, it was gaining right around 5hp and 3tq every two degrees the tunner and showed no sign of knock, he stopped at 29 degrees though.
Old Apr 11, 2012 | 07:53 AM
JUIC3D's Avatar
JUIC3D
Exactly Justin. Dyno is the only tool for this job.
Also, regarding the 5hp/3tq gain for every 2* of timing...I can't speak for everyone, but that's not a very good return for the the risk involved in my opinion.
Cylinder pressures(load on the motor) go up exponentially for every degree of timing added. I'd rather have much a much safer motor with 4* less timing and give up 10whp/6tq then push it to the ragged edge and risk damaging the motor. The risk/reward just isn't there for those minimal gains.
Just my $.02 though
Old Apr 11, 2012 | 01:01 PM
5clubLS2's Avatar
5clubLS2
Just my $.02 though
I agree, all gains are not worth it. I want to stay in a safe zone and enjoy the car. Dont want a max out ***** to the wall tune just from what I know(which isnt much) I thought 30* was a starting pointing with my mods but obviously I am wrong.
Old Apr 11, 2012 | 02:38 PM
JUIC3D's Avatar
JUIC3D
On E85, 30* might be ok, but that certainly wouldn't be my starting point.
Old Apr 12, 2012 | 04:38 AM
lilmiller74
I ment it was still gaining 5hp and 3tq 29* and the tuner said he was stopping there because there was such minimal gain and its more risky with more timing.
To Whats safe timining for ls2
