OEM brake pads
Old Apr 10, 2012 | 07:31 PM
HOXXOH's Avatar
HOXXOH
Default OEM brake pads
Is there a difference between OEM brake pads used on base brakes and those on Z51/F55 brakes? Or even between Z51 and F55?
I don't know which pads came from which car, but they're obviously different. Also the size/shape of the low pad warning spring.
Old Apr 11, 2012 | 10:19 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
There is no diffrence in size and shape, I can not tell you if GM used a diffrent compound, I highly doubt it. At any rate looks like you need new pads I will be happy to help you out with a set of Carboteh brake pads.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Apr 11, 2012 | 04:21 PM
HOXXOH's Avatar
HOXXOH
Thanks, but neither set are currently on my car. I'll consider other pads when mine start getting thin.
The size/shape was only refering to the spring clip used as the low pad warning device, not the pad itself.
Disregarding compound, the visual differences were the clips and the two grooved pad vs. a single groove.
To OEM brake pads
