What year seats fit a 2005?
Old Apr 16, 2012 | 12:50 PM
C7&7's Avatar
C7&7
Default What year seats fit a 2005?
Anyone aware of what years seats are compatible in the '05? I know the seats changed in 2012, but were all 05-11's compatible in any year?
Thanks.
Old Apr 16, 2012 | 03:29 PM
brooklync5's Avatar
brooklync5
If I'm not mistaken all should fit... Only differences might be the harness depending on whether or not you have 1-3lt
Old Apr 16, 2012 | 04:08 PM
BEZ06's Avatar
BEZ06
All C6 seats should fit.
The difference between a 2005 and all other model years is that your 2005 has a way to turn your passenger airbag on/off via the manual switch in the glove compartment.
Starting in 2006 they put in a PPS (Passenger Presence Sensor) in the passenger seat bottom so the airbag turns on/off automatically depending on whether somebody is sitting there or not.
So...I think that even if you put a later model year seat in you shouldn't have any problem. If you put a 2005 in a later car you would have problems unless you transfer over the PPS.
Bob
Old Apr 16, 2012 | 06:22 PM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
Also if your seats have side airbags and new ones dont you'll need the simulators or your airbag system will not function.
Old Apr 16, 2012 | 06:58 PM
C7&7's Avatar
C7&7
Isn't there something different with 2012 seats?
To What year seats fit a 2005?
