LS2 A4, operating temperatures
Old Apr 18, 2012 | 10:29 AM
Tikiman12's Avatar
Tikiman12
Default LS2 A4, operating temperatures
What are the operating temperatures for an LS2 with the A4 automatic transmission.
Oil Temp
Coolant Temp
Trans Temp
I ask b/c I think I am running hot but since I'm not sure what the "OK" temp. range is I really dont know.
Thank you
Old Apr 18, 2012 | 01:35 PM
Don 79 TA's Avatar
Don 79 TA
wish i could help, but i went with a tune and 160 stat
so i know her temps are down in the car compared to what they were
Old Apr 18, 2012 | 01:53 PM
FloydSummerOf68's Avatar
FloydSummerOf68
What temps are you currently seeing?
Old Apr 18, 2012 | 03:06 PM
Tikiman12's Avatar
Tikiman12
used to drive around at 195 then it would go up to about 205 in stopped traffic. (this is coolant, I never noticed the other temps)
But yesterday in traffic all 3 temps went up to 225°F. But this morning while cruising to work I was at 198-200 coolant temp.
I think I need todo drain my coolant and refill with new. Is it necessary to do a flush or can I just let it drain and then add new?
Old Apr 18, 2012 | 07:38 PM
JCtx's Avatar
JCtx
I believe the stupid fan doesn't turn on until 225ºF, so it has to be normal, although I don't personally like it that high. I finished my break-in yesterday on a mountain road, and saw the oil temperature climb to 228ºF (coolant 225º), even though ambient temperature was 60ºF, and I didn't exceed 4K rpm (between 3 and 4K tackling the twisties). I was a little worried, but then remember this information from my C5 days years ago.
Since I don't want to touch my car during warranty, the solution is to turn the A/C on, which automatically turns the fan on high speed, which doesn't happen on its own until 235ºF, I believe. Somebody either correct me or confirm this please. Good luck.
Old Apr 19, 2012 | 07:25 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Changing coolant won't reduce temperatures at all. Coolant doesn't lose it's ability to transfer heat.
Anyway, you are within normal operating temps.
Old Apr 19, 2012 | 07:47 AM
FloydSummerOf68
Your temps are normal.
If you want it a bit cooler just mix more water into the mix. Do a 70/30 mix instead of 50/50. It isn't a bad idea in Houston 100+ degree summers.
I'll be draining my coolant this weekend to refill 100% with water. The supercharger runs a bit warm and I don't want any issues this summer.
Old Apr 19, 2012 | 10:05 AM
Tikiman12's Avatar
Tikiman12
ok thank you guys.
I was just having a small problem with the engine and hanging RPMs. I thought "seems hot" but its not. The problem is I have a vacuum leak at with my Vararam Throttle Body Spacer, it has a cracked down the center.
Old Apr 19, 2012 | 10:30 AM
FloydSummerOf68
ok thank you guys.
If you want another Vararam spacer I have one that I can toss in the mail for you cheap. Should get it next day basically since I'm in Missouri City.
I'm not using it since I put my blower on.
To LS2 A4, operating temperatures
