10.61@124.59
Old Apr 19, 2012 | 09:11 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
Default 10.61@124.59
I ran last night and got a personal best again. Made 5 runs and the first was the worst. I had forgotten to remove my filter element on the first pass.
10.70(filter on) 1.43 124.00mph
10.65 1.42 124.22mph
10.66 1.43 124.20mph
10.64 1.42 124.34mph
10.61 1.42 124.59mph
the DA was 900 on my last pass. I wish I had gotten to run last week in a zero DA condition! My scans show that my 60-118mph times were 6.6s on the 10.68 run 2 weeks ago and in zero DA they were 6.1s. And as a side note on my 10.61 run they were 6.3s which makes me believe that if I do get to run in better air that I might see a 10.56 or 10.57!!
05 A4 vert
ls2 20k miles
l92/l76 (unported)
231/240 617/613
PTB
LS7 injectors
~10.6 compression(stock bottom end)
1 3/4 LG headers
Z06 mufflers
3.42 C5 diff
yank ss4000 converter
Hoosier 275/40/17 DRs
gto spares with M&H
160 stat
stock water pump
stock pulleys
Old Apr 19, 2012 | 09:22 AM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Nice time, what was the 60ft? What cam is in the cam?
Old Apr 19, 2012 | 09:35 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
sorry justin. I updated the specs
Old Apr 19, 2012 | 09:49 AM
JUIC3D's Avatar
JUIC3D
Sweet man, congrats on the killer times. Do you have a copy of the timeslip itself? Bottom 10.6s are pretty awesome
Old Apr 19, 2012 | 09:50 AM
JUIC3D's Avatar
JUIC3D
Geesh, 1.42 60ft is nuts. ALMOST makes me want an auto.... almost
Old Apr 19, 2012 | 10:05 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Very quick car
stanger383's Avatar
stanger383
St. Jude Donor '09
Default time slip
its not my best 60' or my best 1/8 mph but it is my best 1/8 et and my best 1/4 mph
[IMG][/IMG]
Old Apr 19, 2012 | 10:07 AM
JUIC3D's Avatar
JUIC3D
That's a great timeslip, congrats
Old Apr 19, 2012 | 10:21 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
thanks guy! Theres no doubt in my mind after reviewing my run scans it has a 10.55-10.56 in it at a zero DA .... but I may never get one 1! Its unbelievable how well these stock L92/L76 parts run. I cheaped out and put stock head gaskets when I did the head swap instead of thinner ones so I know the compression Is lower than stock right now. Id did take .030 off of them but that's not enough to even get back to stock comp.
Old Apr 19, 2012 | 10:29 AM
JUIC3D's Avatar
JUIC3D
A thinner gasket would definitely help. Have you calculated your SCR and DCR? How close are you on PTV? Is there even room for a .040 Cometic in there without notching the pistons?
Old Apr 19, 2012 | 10:38 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
I fly cut the pistons right in the car .060 just in case. I have been told that .030 off the L92s doesn't quite get you to 10.9CR with stock gaskets... maybe closer to 10.6CR. So far pulling my vararam filter out of the car has netted .05 improvement both times that I tried it. Also I have been against a wall in that no matter what changes I make to my tune it never really responded....that is until I removed the filter. Now every time I make a tune change it improves or falls off. Apparently the filter was only allowing X amount of air in. The car used to run the same ET and MPH whether it was 60* or 90* Maybe that alone will help someone else who seems to have that issue. I wonder how much better it would run with a ported intake...hmmm.......
Old Apr 19, 2012 | 12:27 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
got some go pro of a few runs from last night
http://youtu.be/zzFZuOjiA5M
http://www.youtube.com/watch?v=vS-cEZgpHhg
Old Apr 19, 2012 | 01:14 PM
ctusser's Avatar
ctusser
OK, that did it... My next vette is gonna be an auto
Old Apr 19, 2012 | 01:15 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
Yesterday was perfect for the track. Congrats on the time and I wish I could have been there. I will see you next week without a doubt!
Old Apr 19, 2012 | 01:18 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Ctusser my c5 vert was the A4 too. I wouldnt have it any other way 5 runs and the 60s were 1.424-1.437. and my DRs are 2 years old now!!
Old Apr 19, 2012 | 02:28 PM
LS1LT1's Avatar
LS1LT1
Congrats stanger
Old Apr 19, 2012 | 10:44 PM
HOXXOH's Avatar
HOXXOH
Congrats on the new PB. Gotta love that 60'.
Finding good DA may be tough, but you know when fall gets here you're ready.
To 10.61@124.59
Old Apr 20, 2012 | 12:28 AM
STROKD's Avatar
STROKD
What rear wheels are those as the offset wont work for my car (too low).
Also, do you have any transmission work done? Congrats on the new best.
Old Apr 20, 2012 | 07:14 AM
pit-man's Avatar
pit-man
Greats runs man. Love the Auto!!
Running my Silverado with a Yank 3400 Pro stall and can't get my sixty below 1.53. That 4000 of yours is launching hard. Might be time for a change.
Old Apr 20, 2012 | 08:48 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
the rear wheels are c5 Z06 fronts that I painted black with 275/40/17 hoosiers. they Rock!
the trans is stock except when when we pulled the trans out to do the converter swap I left my garage to go get some dex6 and when I got back my trans was totally apart. My buddy knows transmissions and when I got back I said "why did u take it apart?" he "oh I just wanted to see how everything looked inside" . I bet I wasn't gone 15 minutes and it was totally apart! to answer your question the only thing he did besides look at it was put borg warner 3-4 clutches and a borg warner sprag...he said the sprag is the weak link. the total parts cost was about $44.
Get the Yank ss4000. I couldnt be happier. Dave a great guy to deal with at yank too!
