LS3 injector question
I have a cam that I was planning on putting in my LS6 but didn't get the chance to before the motor went. I have SVO 30 injectors now (they flow 36# on the C5 fuel system) as it was generally recommended to change out injectors if doing a head/cam package to keep the duty cycle from being up at the 100% mark.
Well here's a few questions:
1) It's my understanding that the LS3 has 43# injectors....is that correct?
is it the same for the Camaro?
2) Will the stock injectors be adequate with putting my cam in this LS3? I may do some head work as well....
3) Anyone know what the stock cam specs are off hand?
4) Also anyone know what the compression of the LS3 is, and is it the same for the Camaro?
Figured the C6 section might have these answers. I know little to nothing about these motors as I have spent the last few years with my head stuck in the C5 section...
Any help would be appreciated
"just" is a touchy word here. It would really suck to spend the money to tear the thing apart and put it back together, and tune, only to find out that you're out of injector, and have to spend another 2 grand on parts and labor to rectify the problem.
thanks.
Stock LS3 Injectors ... 41.7 Lb/Hr @ 58 PSI (438 cc/Min)
_________________________________
See Chart Below ... Looks like the LS3 injectors will support 567 Flywheel HP (Approx 493 RWHP) at 85% Duty Cycle
BTW ... The chart below don't show it, but ... At 90% Duty Cycle, the LS3 injectors should support 600 Flywheel HP (Approx 522 RWHP)
