Preformance chip
Old Apr 24, 2012 | 10:01 AM
jonesde2's Avatar
jonesde2
Default Preformance chip
Yeserday I saw an article on G-FORCE that claimed a gain in HP of up to 60. A 4-7 improvment in MPG. All this was guranteed. Has anyone had expirence with this product. Sound to good to be true.
Old Apr 24, 2012 | 10:25 AM
EVRose's Avatar
EVRose
It's a scam. Especially if they say it fits a C6. Our cars dont use that type of chip.
Old Apr 24, 2012 | 10:29 AM
ZYUL8r's Avatar
ZYUL8r
That actually isn't a chip at all, it is a resistor set to inaccurately report Intake air temperature to the computer, making your car run rich.
Old Apr 24, 2012 | 10:39 AM
jonesde2's Avatar
jonesde2
Default Performance Chip
If it make the engie run rich how can it improve MPG?
Old Apr 24, 2012 | 10:40 AM
ZYUL8r's Avatar
ZYUL8r
Exactly.
Old Apr 24, 2012 | 10:46 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Elmer
Old Apr 24, 2012 | 10:47 AM
Vette_DD's Avatar
Vette_DD
I thought you said it increased HP?
For sure, it won't do that.
Old Apr 24, 2012 | 10:49 AM
jonesde2's Avatar
jonesde2
That what their ad in this forum states.
Old Apr 24, 2012 | 11:40 AM
Toilets's Avatar
Toilets
Out of curiousity, why won't it work exactly? If it tricks the computer to think the IAT's are a lot lower and therefor less timing is being pulled, wouldn't that essentially generate more power?
60 hp is total bs but 5hp is very obtainable I think.
For the record I would never do this.
Old Apr 24, 2012 | 11:55 AM
ZYUL8r's Avatar
ZYUL8r
True..you are correct....its kinda like when you first start your car on that cold morning and it seems to have more power. So if this entices one to to send a false signal to get power, that's fine, it isn't my preference, but to each his own, i won't knock down someone who wants it. Just stating the facts.
Old Apr 24, 2012 | 03:40 PM
Mike's LS3's Avatar
Mike's LS3
Lower the IAT temp's will not generate power, but prevent the ECM from pulling timing and reducing power. This starts to happen when the IAT temps reach 86*F. The idea of pulling timing is to prevent detonation in the warmer to hot climates.
You are better off installing a true CAI which will help keep the IAT's down and lean out the pig rich WOT A/F ratio which will then add hp.
Old Apr 24, 2012 | 03:44 PM
ZYUL8r's Avatar
ZYUL8r
So if the ECU is pulling timing when the IAT reaches 86 degress to prevent detonation, I wonder what happens if you trick the ECU, then it doesn't pull timing, then you get detonation? Ouch.
Old Apr 24, 2012 | 03:47 PM
eboggs_jkvl
Moderator emeritus
The KR sensors better have their $hit together and pull the timing or you'll break something.
Old Apr 24, 2012 | 10:02 PM
Mike's LS3's Avatar
Mike's LS3
Old Apr 24, 2012 | 10:27 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Elmer
The car does not take a "chip". Get the car tuned by a good tuner and maybe pull out a couple of ponies. You are not getting 60 HP from it though!! If you want 60 HP, you're going to have to do more than a tune.
Old Jun 29, 2012 | 09:15 PM
grumpstar's Avatar
grumpstar
I also saw it the other day, I called and tryed to ask questions, the guy said just buy it. When is someone going to start stinging these con artist up. It's a shame when people like that get away with possibly harming someones engine.
Old Jun 29, 2012 | 10:14 PM
Vette_DD's Avatar
Vette_DD
http://forums.corvetteforum.com/foru...s-or-more.html
To Preformance chip
