LS3 MAF Wires
Old Apr 25, 2012 | 10:50 AM
Steven Ressue's Avatar
Steven Ressue
Navigator
Default LS3 MAF Wires
I made a big mistake trying to shorten my MAF wire harness. I have an LS3 Erod and I cut the MAF harness wires before I looked and saw there were two tan wires. Now I'm not sure how to reconnect them. Is there a way of finding out what tan wire goes to the "E" pin "intake air temp sensor signal" or what tan wire goes to the "D" pin "low reference"?
Old Apr 25, 2012 | 11:34 AM
PKinsella's Avatar
PKinsella
Sounds like you need a wiring diagram and a volt meter!
Old Apr 25, 2012 | 12:26 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Mass Air Flow (MAF)/Intake Air Temperature (IAT) Sensor
Pin Wire Circuit Function
A 0.35 YE 492 Mass Air Flow (MAF) Sensor Signal
B 0.8 BK/WH 451 Ground
C 0.5 PK 539 Ignition 1 Voltage
D 0.35 TN 2760 Low Reference
E 0.35 TN 472 Intake Air Temperature Sensor Signal
Old Apr 25, 2012 | 04:29 PM
Steven Ressue
Navigator
I have the plug diagram. What I need is how do I determine which tan wire coming from the ENGINE HARNESS is the "low reference" and which tan wire is the "Intake air temp sensor signal"?
Old Apr 25, 2012 | 04:46 PM
PKinsella's Avatar
PKinsella
I don't know what it is for this car specifically, but it seems like the reference should read around 5v continuous (guessing it's a 5v reference), while the the IAT wire would read something different, but I'm not sure how much different it would be. And the IAT signal should vary while the reference signal shouldn't.
That's just something I would experiment with if it were me.
Pretty stupid to have two of the same color wires!
Old Apr 25, 2012 | 05:03 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
PM me your cell number or email, I have a great close up picture I took recently for a friend in a similar situation I will send you.
Old Apr 26, 2012 | 12:31 PM
Steven Ressue
Navigator
Located information on pin outs and did a continuity test from the ECM connector to locate what tan wire goes where. All set.
Thanks to all for the help.
Steve
Old Aug 1, 2018 | 08:12 PM
Blackonblacksls's Avatar
Blackonblacksls
Do both of these wires go to the break out iat sensor?
Old Sep 14, 2019 | 11:47 AM
Ralph Edward Congdon's Avatar
1st Gear
I did exactly the same thing! Did you get the information you need? If so will you share. Thank you, Ralph Congdon futurepastco@hotmail.com
Old Sep 10, 2024 | 01:37 PM
Cajun TurboZ's Avatar
Cajun TurboZ
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Had the two tan wires get cut while installing CAI. Does one of the tan wires measure 5v and the other different? Thanks
Old Sep 10, 2024 | 01:49 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Yes, one tan wire is a 5 volt reference and other tan wire is a low reference or computer ground.
Old Sep 10, 2024 | 01:59 PM
Palmer's Avatar
Palmer
CorvetteForum Editor
Just checked my LS3 E-ROD crate motor with the GM harness.
Tan wire with the 5V is the outside pin (I'm not certain if that's A or E in the post 3 diagram, i think it's E).
Old Sep 10, 2024 | 02:13 PM
C5 Diag's Avatar
C5 Diag
E is the 5 volt reference…it is a 5 wire connector (A-E) and pins D and E are the end terminals.
To LS3 MAF Wires
