Change Door Pads
Old Apr 27, 2012 | 06:34 AM
jforce's Avatar
jforce
Default Change Door Pads
How do you change the door pads on 09 c6? I think the one on drivers side is either dirty or going bad.
Thanks in Advance
Old Apr 27, 2012 | 06:49 AM
68birdls1's Avatar
68birdls1
I just had to do this the other day on mine. I've removed it before and cleaned the pad but for only like $15 new from GM, I won't waste my time with that again haha.
Very easy to remove bud.. With the door open, you should see 2 phillips screw hold the door handle on. Remove those two screw and if the outside unit has never been removed before it will take a little to get it off. Once you pop that loose all you do is unplug the old switch, plug in the new and put it back together. Shouldn't take more than 5 mins.
Old Apr 27, 2012 | 09:37 AM
jforce's Avatar
jforce
Am I correct that after changing the door pad that you'll have to re index the window?
Old Apr 27, 2012 | 10:16 AM
EVRose's Avatar
EVRose
No. Thats only if you disconnect the battery.
Old Apr 27, 2012 | 03:55 PM
jforce's Avatar
jforce
Update I just changed the door pad on the drivers side where I was having the problem & wham!!! problem solved. Thanks guys for all of your help. Not even 5 mins (4.5 was spent drinking Mich Ultra LOL)
Old Apr 30, 2012 | 11:53 AM
conjosC6's Avatar
conjosC6
I changed mine but the door still doesn't open. Its clicks, like its engaging and the window comes down like its going to open but the door will not open. It will not open from the inside button either. The only way I can open it now is by the emergency release from the inside. Any ideas??
Old May 3, 2012 | 11:58 AM
skylarkul's Avatar
skylarkul
Default Same Problem
I have the same problem. I'm thinking it may involve the window indexing. I changed the pad and at the same time, I had the battery disconnected - for another reason - and it seemed to work fine for a day but, I realized I had not re-indexed the windows and, they weren't indexing down when I opened the door. As soon as I re-indexed the windows, the problem came back.
Old May 3, 2012 | 12:08 PM
conjosC6's Avatar
conjosC6
Wild Bill is also having this problem. He is changing his door lock assembley to correct the issue. I will atttempt as well with the help of Bill and this forum!!
Old May 10, 2012 | 06:17 AM
skylarkul's Avatar
skylarkul
Default Nope
Nope. Re-indexed the windows and it worked a couple of times and then failed - intermittantly. Tried it with leaving the windows down and still fails.
I am definately open for suggestions.
To Change Door Pads
