LS3 Cold air Intake - Worth It???
I heard that the LS3 Intake and filter are as good as you can get.
Is that true, or is there some gains to be had from an AirRaid with open shroud.
Thanks for any input.
Vararam
Airaid
K+N
In no particular order, should perform better than the stock (major improved airbox over previous versions) air box.
You will never see a Katech, LG or any other vendor car with a stock airbox.
As the LS3 uses the same Donaldson filter as the Z06 with 505 HP, I would think it would easly flow enough air for 430/436 HP. Plus the LS3/LS7 GM Donaldson filter element is good for 45,000 miles under normal driving conditions.
If you're doing a cam, high-flow exhaust, etc, then increasing intake flow w/ K&N type open filters may make sense. The OEM's strive to get the most possible performance from cars like the corvette, but they rarely spec these open type filters, the new Shelby500, etc being the exception.
I understand the stock Donaldson filters trap more/finer dirt & grit, although perhaps not flowing as much as a Haltech, Vararam, K&N, etc. If you plan to keep the car forever this may be a concern, but not as much if you trade cars out frequently. The amount of dust & dirt your filter ingests(if you drive dirt roads or dirt driveways, etc) is a consideration.
My practical experience is in the offroad motorcycle racing world, where the washable dual-foam filters, Twin-Air, Uni, etc are preferred over the more open 'K&N type' filters b/c they trap more dirt. There's substantial real world examples of increased valve seat & engine wear from using these open type filters in dirty environments. We ran dual-element foam filters in the Baja1000, but I use K&N's on my street bikes, & in my cars for years, because they rarely, if ever, see dirty environs.
But the more I read, the more I feel the stock filters breathe/flow sufficiently, while protecting engine internals better, & the trade off of open filter elements minimal performance increase isn't worth the increased engine wear, for me. Again, this is all just personal preference, my .02, etc.
I bought the attack blue and cut an openeing in the shroud to allow more air in and feel this is as good as any aftermarket CAI that can be bought. You can go one step further and by the scope to get a more forced air to your cutout hole but that might cause turbulance in the MAF, so I didnt do it but some have and have had no problems.
The bigger your rear hole is the bigger your front hole has to be. lol.
http://forums.bimmerforums.com/forum...d.php?t=410836
Stock I put down 378rwhp, 5 minutes later with the Airaid CAI on the car I did 2 back to back runs and put down 385rwhp. Car actually richened up just a little and with a custom tune prob would pick up another 2-5rwhp just cleaning up the WOT/PE map.
So with that, it counters what all the naysayers say about the Donaldson filter being the best and not leaving any room for gains on the table. The Airaid setup picked up 7rwhp over stock.
I've dyno'd a few bikes & cars, they all made more power on each sucessive dyno run, the 3rd dyno run showing a significant increase over the 1st run, like 10+ rwhp. Shutting down the motor & letting it heat-sync for @ 10 mins between runs let them truly reach peak-power operating temps. This was initially a surprise to me, that motors don't make their true power until they're really hot.
So I would take this into consideration when comparing your first to your 2nd dyno run. I'd be interested to see results on three runs w/ the stock air intake one day, then 3 runs w/ the Airaid the next day..air & motor temps being consistent.
