Underdrive Pulley Questions
Old Apr 30, 2012 | 12:26 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Default Underdrive Pulley Questions
I have used them on others cars but not the vette. I have a 2010 LS3.
1) What is the percentage of underdrive and are there different percentages offered for the vette.
2) Average HP gain; any dyno or track results from just adding a pulley.
3) Does it affect the cooling or charging system, if so how much.
4) Best brand to use and price range.
If I do one, I would like to get the right one. Thanks
Old Apr 30, 2012 | 01:27 AM
CandyRedDevil's Avatar
CandyRedDevil
I recently did one on my 08 and though I do not have the timeslip to back it up, it DEFINITELY is stronger... NO DOUBT.. This is an A6 car with longtubes and already runs 12.20's . Its an SLP 25% and theres no ill affect of cooling or charging... PLAN ON ABOUT 3-4 hours for the install..
Old Apr 30, 2012 | 08:27 AM
wazslow's Avatar
wazslow
Unless you are doing a cam swap or something, its not worth the gain for the amount of work involved to swap it. The whole steering rack and all has to come out to get the pulley off. I put a 25% u/d pulley on mine when I did my cam swap, no way I would have done it otherwise. People say they are work 8-10rwhp or so. You may have to raise the idle slightly to get proper charging at idle. (Not an issue with a cam swap as the idle is normally increased anyway).
Old Apr 30, 2012 | 09:17 AM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
10% and 25% are your 2 choices
I don't know of anyone who has done a back to back test, but 7-10whp is the norm for a 25% UDP. The car doesn't make any extra power, but power is freed up as a result of the slower spinning accessories.
This is a highly debated topic when it comes to an UDP. Some people have issues, but from the research I did before buying one myself, the increased idle speed makes up for the slower spinning alternator at idle and no adverse effects are present. I have a 25% UDP in my car and also a tiny 17lb motorcycle battery in my car and have yet to experience any issues with charging or starting after the car has sat for over a week. I do not use a trickle charger. The deka battery just plain works.
After reading of multiple people snapping timing chains with a particular UDP, I would go with either a Powerbond or ATI. I have a good buddy(taken19) who road races often and snapped a C5R timing chain within a year. There have been a few different threads about this and road race+that brand of UDP=bad harmonics and a broken timing chain.
See answers in quote.
Old Apr 30, 2012 | 09:57 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Thanks for the replies. Sounds like I might as well do a cam and pulley at the same time along with drilling the crank for a pin if or when I do this.
Justin approx. what would the new idle speed be to cover just a pulley change? and which brand of pulley would be your choice at this time?
Old Apr 30, 2012 | 10:02 AM
JUIC3D's Avatar
JUIC3D
I had a 750 idle for months and had 0 issues with starting, voltage, a/c blowing cold, etc. The car ran perfectly. Considering that's a 25% idle speed increase from stock and I had a 25% underdrive pulley, I think it was a wash.
I haven't heard anything negative about the Powerbond brand of UDP but if I had to do it all over again, I'd go with an ATI I think. It's possible the notion of snapping a timing chain is very rare but even still, the extra $300 would be worth the peace of mind to me. The only reason I didn't buy one to begin with was because I was misinformed and thought ATI did not come in a 25% version.
Old Apr 30, 2012 | 10:37 AM
taken19's Avatar
taken19
Track Junky
Do not buy ASP, that's what most likely caused my timing chain to break. In a discussion with Jason Katech, he told me that ASP pulleys have been responsible for at least 12 timing chain failures that he seen. As Justin mentioned, ATI or Powerbond appear to be the 2 best out there. Don't make a $10k mistake like I did using an inferior brand...
Sean
Old Apr 30, 2012 | 05:12 PM
Ragtop 99's Avatar
Ragtop 99
ATI recommends the 10% UD once you get to about 500 RWHP. The larger size provides more dampening capability.
I would not hesitate to install one when you do your cam swap.
Old Apr 30, 2012 | 06:21 PM
narfdanarf's Avatar
narfdanarf
I just bought a Powerbond based soley on the recommendations of this post. My stocker looks like it's about to fly off.
Old Apr 30, 2012 | 07:01 PM
JUIC3D's Avatar
JUIC3D
PB is a good choice. I'm very happy with mine.
Old Apr 30, 2012 | 08:06 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
That's what I went with.
Old May 23, 2012 | 02:31 PM
Kerrdogg's Avatar
Kerrdogg
Just remember if your Grand sport is a Manual and then has the dry sump your crank snout length will be different as well as the bolt and the regular LS# pulley won't work, haven't done all the research yet but I am looking (will call ATI) and think the ZO6 pulley might be the way we'll have to go...
Old May 23, 2012 | 10:41 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I went with a Powebond 10% UD pulley and have had it on for a little over a year with no issues. I ordered the ATI and they were on back order for a while at the time so after much research switched my order to the PB. I think it is a very nice piece and would buy another without hesitation.
Sean
Hey Sean,
What valve spring were you running?
Old May 23, 2012 | 11:00 PM
MikeSVT04's Avatar
MikeSVT04
for 5-10hp and the possibility of a broken timing chain I passed on doing one.
like others have said, powerbond and ati are the good ones.
Old May 24, 2012 | 12:01 AM
LoneStarFRC's Avatar
LoneStarFRC
Agree on the PB. I've had the 25% for a few years and no issues. Pin your crank snout when you install one. Easy to do.
Old May 24, 2012 | 06:23 AM
taken19's Avatar
taken19
Track Junky
Originally Posted by Neumonic2002
Hey Sean,
I was using PSI beehive springs at the time. Why do you ask?
Old May 24, 2012 | 10:05 AM
Neumonic2002
In tracking the broken timing chain threads there were two pieces coming up often, the ASP was the more predominate but there was a certain spring in probably 75% or more of the reported failures..probably more of a coincidence as they were pretty popular throughout the timeline.
Old May 24, 2012 | 11:16 AM
C7/Z06 Man's Avatar
C7/Z06 Man
What spring was that?
Old May 24, 2012 | 11:26 AM
taken19's Avatar
taken19
Track Junky
Yes I'm curious as well. PSI with the old motor, lunatic with the new LS3 motor.
To Underdrive Pulley Questions
