Brake upgrade
Old May 2, 2012 | 10:51 AM
9157's Avatar
9157
Naples FL
Default Brake upgrade
I have an '08 base coupe with 106k miles on the original front brakes...I think it is time for an upgrade...the stocks brakes Are great for long wear, however, I have had a slight pulse (probly due to heat and highway stops!) Any suggestions? Can I go to a bigger rotor and keep the same caliper?
Old May 2, 2012 | 11:17 AM
FloydSummerOf68's Avatar
FloydSummerOf68
You can go to a Z51 brake setup and keep the stock calipers. You just need different caliper brackets.
Z51 rotors, better pads and steel brake lines are a very good and VERY affordable upgrade.
Old May 3, 2012 | 09:42 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
I will be happy to help you with a pad upgrade. I assume this is just a street car? If so I would look at Dba 4000 series rotors, dot 4 fluid, SS lines and Carbotech 1521 brake pads.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
To Brake upgrade
