Before the dual fan install – I could hear the stock fan coming on pretty loud. LG Motorsports did the tune on the car and adjusted the fan temps - so I can assume that the stock fan was working properly – as it was noisy when the temperatures climbed over 215.
I am using the stock GM controller and the dual fans come on but I don’t hear them working so loud. It’s like they’re working maybe at 50% or so and my temperatures in traffic are higher than before.
I don’t think the fans are the problem. They spin free and aren’t touching anything. Do you think the setup requires a new ECM calibration?
Anyone run into a problem like this? Thanks guys.
I think the obvious question is: what temps did LG program the fans to come on?
Then, is your coolant topped off, and of the right mixture?
Check for debri in the air dam areas just to be sure its not something silly.
The stock fan was coming on at around 192 and really humming at 215.
Before the dual fan install - all was well. So - there are no coolant leaks nor is there any debis in the radiator area. This has got me stumped. I even asked John at Dewitts and he's stumped too.
Here's a bump for ya.
When you swapped fans, I'm assuming you disconnected the hose running to your rad? Perhaps you have air trapped in the system. This will cause overheating.
Corvettes self-burbs for the most part, and any trapped air should quickly work out of the system, resulting in lower reservoir levels (if there is any significant volume of trapped air).
When you replace the fan assembly - there is no need to disconnect any coolant hoses - so not air is in the system and no burping needed.
Reason: error
How are the dual fans wired, series or parallel? What is the wattage of the dual fan package compared to the OEM single fan unit. What I'm leading to is, a dual fan package may a good idea for radiator core coverage but, a poor idea if they are running at half speed due to controler limitations. You have some sytem investigation required.
The fans are pre-wired from Dewitts and there's a simple 2 wire hook up to the factory wiring. The connections were soldered. As far as the wattage they're pulling .......... I don't know. The expert at Dewitts technical didn't mention any wattage issues versus the factory stock fan.
Gotta keep looking - I guess.
Thanks for the input.
Without seeing any fan data and going by what you said in your opening post, I'd say that the dual fan package does not flow as much air as the single OEM fan. You did not state why you converted to a dual fan system. The electric fan is there to provide airflow to the condenser and radiator from zero to approx. 10 MPH. Beyond that speed it presence is a restriction to the air flow created by the forward movement of the vehicle. There are performance requirements that must be met for park idle and city traffic conditions at 100 degrees F and with max A/C. Also cost and weight. From my experience with my car, except for terrible noise at high fan, I think the powertrain cooling people at Chevy did a good job with the OEM cooling fan.
This is what the Dewitts website says about the fan package:
Spals dual fan package boosts air flow up 40% from stock. This fan package only fits our Direct Fit radiators. Note: Factory wiring will need to be cut and spliced in order for the factory ECM to operate the fans.
That's why I upgraded my stock factory GM single fan.
So you swapped to the DeWitts direct-fit radiator at the same time then?
I wrestled with cooling problems for many months. This is slightly off-subject but something to consider when changing fans or increasing the amount of time the fan runs.
