Just changed the fluid in my 07 Z06. With the car level I do the same as I do with my classic cars except filled till it just runs out. With the Muncies you fill just below the fill plug. What my concern is the book says 4.5 Qts and it only took 3.5? Should the car be raised front or back to get the extra quart in?
I refill through the reverse light switch opening.
