Trying to decide on a cold air induction system?
The Halltech Super Bee MF103 has a 102.4mm read arear at the MAF and has a larger plenum volume than the former champ, the Killer Bee II, but 20%. It has a girth with 1" larger circumference and accelerates the massive air volume at peak velocity at the 105mm outlet.
Using the stock 90mm throttle body, port blended or not is the point of flow restriction, albeit not by much. Ported throttle body is incorrect terminology for cleaning up the entrance of the stock throttle body, since real porting would involve enlarging the 90mm throttle blade. Those that use the Nick Williams throttle body are getting 101.9mm vs. 90mm and even our 429 650 HP alky motor only benefits 4 HP on the Katech dyno.
The FAST LSXR is 99.6mm, not 102, so when you look at restriction to flow, the MF103 will never be that point.
When the Lingenfelter, Callaway, or VR intakes beat our records, we'll quit beating our chest. (until the next win)
Gary's records:
I've had ALL three.
Performance Mods (if any): AR Headers, RPS Clutch, Vette-Air, Halltech KB, Ported TB and Intake, 4.10 Gears
Category submitted for: Bolt-On
60'.............1.444
330'...........4.290
660'...........6.633
660’ mph...102.59
1000'..........8.642
1320'..........10.340
1320’ mph…132.04
Name of the track: Atco
Date of pass: 10/20/09
Performance Mods (if any): RPS BC2 Clutch, Halltech KB II, Vette-Air, AR Headers, Ported FAST 102, Ported TB, EWP, 4.10s
Category submitted for: Bolt-Ons without Internal Engine Modification
60'.............1.386
330'...........4.155
660'...........6.475
660’ mph...103.71
1000'..........8.457
1320'..........10.132
1320’ mph…135.55
Name of the track:Atco Raceway
Date of pass:3/20/11
Performance Mods (if any): RPS BC2 Clutch, Halltech SBMF 103, RPM 4.10s, Vette-Air, FAST 102, Ported TB, ARHs
60'.............1.366
330'...........4.119
660'...........6.378
660’ mph...109.17
1000'..........8.331
1320'..........9.973
1320’ mph…137.72
Date of pass: 12/3/11
What about idle quality, long term fuel trims? Check out our prototype testing back when we first started the plastic version of the Super Bee (called it Killer Bee back then):
The MF103 makes the stock intake look like it was made by amateurs:
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Watch out for RPM Transmissions. They have a Z06 with major power and CR running E85. TJ expects to break into the 9.8 range. He runs the SBCF112.
The Halltech intake design places the maf sensor(which includes the IAT sensor) forward of the engine bay and out of the warm air that is a result of the motor running. Moving the maf forward and shielding it with the beehive, keeps unwanted warm air at bay and when you notch the radiator shroud, you are provided a nice stream of cool ambient air. Given that there will always be residual heat coming from the motor, you wont' see IATs be exactly the same as ambient, but I log my motor regularly and unless I'm sitting in stop/go traffic, my IATs stay right around +3 of ambient. If it's 75* on my a/c readout, I'll see 78* on my IAT when I scan.
Hope that makes sense.
Heres a challenge for Halltech, install your CAI on a "totally" stock Grand Sport and see what kind of ET it runs. Please let us know before the track visit and then report after. My LS3 (430HP) A6 GS ran a 12.01 @ 117 MPH using a "modified" Z06 (no sound box on Z06) OEM assembly with the factory paper filter to make a "home made" CAI.
Other than the home made CAI the car was completely stock at the time. The old 12.01 time slip with info located in 1/4 mile section.
