Clarification on C6 trans/diff changes from 2005-2012................................
BASE C6
1. 2005, oddball year, 5 bolt diff and T56(also had an extra switch on trans for shutdown??), can be wired into other switch if newer trans used
2. 2006/2007 8 bolt diff and T56 27 spline
3. 2008-2012 8 bolt diff and TR6060 27 spline?? (2010-2012 retained the 27spline?)
Z51 2005-2009 had unique gear ratios
2010-2012 GRANDSPORT(same diff as Z06)
1. TR6060 30 spline, 30 spline Z06 diff
Same trans spec as Z06, but different gear ratios
2006-2012 Z06(all 30 spline trans/diff), Diff webbing noticeably stronger, internals different from base
2006/7 T56 w/ Z06 diff
2008-2012 TR6060
2009-2012 ZR1
TR6060 w/ unique ZR1 diff(case webs thicker/other internal changes??) trans also has unique gear ratios
