A6 shift question
Old May 12, 2012 | 06:56 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Default A6 shift question
For some reason suddenly my car doesn't shift as it used to. I went to the track to have some fun and when in drive, instead of shifting at around 6k as its programmed,(and always did), it was hitting the rev limiter. A log showed it going to 6800. When shifting manually it shifts fine and when in sport mode it also shifts ok. Sport is programmed a little higher than drive and I like the drive shift points better so I usually use that.
any ideas why it would suddenly start doing this?
thanks
Old May 12, 2012 | 07:20 PM
captainbob's Avatar
captainbob
thanks
Have done any recent tuning to the car? Do you have a copy of the tune and can you reflash your car?? Or have your tuner reflash.. This may help.. Also, w/ your power your probably looking at beefing up your tranny anyways as that is your weak link.. Give the guys at Century in Texas a call.. They are awesome A6 guys..
Old May 13, 2012 | 07:35 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
No changes in the tune since last time out. I know the tranny is the weak link but I don't think the tranny itself is bad because it shifts fine manually and in sport mode. I'm going to my tuner this week so hopefully he figures it out.
To A6 shift question
