will G6x3 fit?
May 12, 2012 | 07:52 PM
will G6x3 fit?
been thinking about going to a G6x3.
will this cam fit without touching the heads or pistons?
May 12, 2012 | 07:58 PM
You need to add a little more info...
What motor, LS2, LS3?
What head gaskets will you be using / will you be milling heads?
May 12, 2012 | 08:06 PM
Yes, if they are untouched (stock). Great cam too
May 12, 2012 | 08:12 PM
ls2
im not going to touch the heads. just to see what it will do.
but i have all the other goodies.
if it will work i think it will sound awesome and make great power.
any thoughts?
May 12, 2012 | 08:19 PM
May 12, 2012 | 08:29 PM
The sound and lope at idle is. Ontrolled through the tune. You can make it sound however you want with the right tuner.
Joe G has a G5X3 he probably has good insight with this cam.
May 12, 2012 | 08:31 PM
Also, go to LG's website. In the pics section they have many dyno graphs of different on os for you to see. The G6X3 has proven to make great power.
May 12, 2012 | 09:08 PM
im sure this cam will make power.
im trying to figure out if it will fit in an LS2 with out touching the heads, pistons etc..
has anyone done a G6x3 cam only?
or have a better idea?
