A Post Inner Panel Removal
Old May 13, 2012 | 12:24 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default A Post Inner Panel Removal
I want to run some wiring inside the A post inner panel. How does that panel come off? Help please.
Old May 13, 2012 | 12:49 PM
Streetk14's Avatar
Streetk14
It's just held on with trim clips, but you will need to remove the trim cover that is just below it, too. If I remember right, that lower piece (that runs along the dash panel) has a clip that goes through the A-pillar cover. Just use a plastic trim tool and be careful. That lower piece has a long plastic finger that is easy to break if you pry in the wrong spot.
Old May 13, 2012 | 03:48 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Many thanks for the help
To A Post Inner Panel Removal
