I just installed a 418 ls3 in my car and on idle the oilpressure goes to about 20-22 once you rev it it goes to around 45-60 is the idle pressure to low?
Using Mobil 1 5W-30, at 180'F, our 2009 LS3 shows 27 psi at idle.
So yours is definitely lower than ours. Your engine could have been set up that way (deliberately loose), or there could be a problem. Can you talk to the engine builder?
