Modded ls3 owners step in...
Old May 15, 2012 | 03:30 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Default Modded ls3 owners step in...
If ya don't mind, could you please list your mods and hp/tq numbers, and even et's if you have them. I am getting together ideas for my next car. After owning a heavily modded c5Z for awhile, I think I want some open air driving and am looking at GS's. I really do like the ls7, and the potential it has, my dad has a nice c6Z, but my wife and I at least want a coupe, if not a vert.
Starting mods would be headers, cam (fi friendly) etc, then eventually an Ecs of a&a kit.
So, lemme know what you guys have so I can get an idea on what it takes to reach my goals. Thanks!!
Old May 15, 2012 | 04:50 PM
MikeSVT04's Avatar
MikeSVT04
i have a 10 GS mn6. I like the targa bc its best of both worlds. some say its to windy....i don't mind it one bit.
My mods.
Halltech intak
ported tb
kooks 1 3/4 headers
kooks catted 3"x pipe
z06 borla stingers
Texas speed 229/236 cam.
dyno on a very hot day 470rwhp and 420tq.
Old May 15, 2012 | 05:19 PM
paydirt's Avatar
paydirt
'08 base coupe with 18,000 miles
A&A T-trim supercharger, 7lbs of boost
ARH long tube headers
ARH catted mid pipe
Gutted Z06 axle back
Lethal Performance Top Secret cam
Snow Meth kit
666whp/560wtq
Old May 15, 2012 | 05:40 PM
82XGOLD's Avatar
82XGOLD
I am interested in the responses as I am looking to follow a similar path with my 2008.
I don't have numbers yet but here are my performance mods so far.
Kooks 1 3/4 coated headers
Catted X Pipe
B&B Route 66 Exhaust
Haltech CAI
MSD Wires
160 T-Stat
Tune
Old May 15, 2012 | 06:38 PM
Fly'n Family's Avatar
Fly'n Family
N/A 08' LS3
- Custom grind cam
- 3 bolt camshaft
- double row timing chain
- Manley Nextek dual polished springs
- Manley dual spring titanium retainers
- new spring seats
- viton valve seals
- valve work
- upgraded HVHP ported oil pump
- tr6 plugs
- stage 3 hand ported and polished cylinder heads - 365 cfm
- ported throttle body
- American Racing 1-7/8" longtubes into a custom X pipe with hf cats
- B & B Fusion dual mode exhaust
- Hinson motor mounts
- 160 thermostat
- Halltech SuperBee MF103 with Beehive
- full blueprinting and balancing
- tune and alot of fine tuning
531/486 rwp
Sound clip: http://www.youtube.com/watch?v=Poc65pfbxkI
Old May 15, 2012 | 08:56 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
My mods.
Halltech intak
ported tb
kooks 1 3/4 headers
z06 borla stingers
Thanks Mike! That is also what i was somewhat afraid of, really nice mods, decent size cam, but less power than a bolt on ls7. Its gonna be a trade off, no top...or power???
ARH catted mid pipe
Snow Meth kit
666whp/560wtq
That's inspiring!! Hope to eventually go FI and and be in the ~650whp range for a weekend warrior, but it won't be cheap!
With those numbers, you should get a plate that says devil inside!!
Originally Posted by Fly'n Family
N/A 08' LS3
- Custom grind cam
- 3 bolt camshaft
- new spring seats
- viton valve seals
- valve work
- tr6 plugs
- 160 thermostat
531/486 rwp
Nice na numbers. Looks like a good set of heads and cam selection might be key to getting big na numbers!!
Thanks guys, keep em coming!!
Old May 15, 2012 | 09:23 PM
CDaniel525's Avatar
CDaniel525
08 MN6 w/ 38k miles
Kooks LT Headers. O/R X-Pipe, Z06 Mufflers
Vararam
160 TStat
235/243 .620/.623 114+1 cam / underdrive pulley / other supporting goodies
Ported TB & IM
494rwhp / 435rwtq
Old May 15, 2012 | 09:27 PM
mowe's Avatar
mowe
Intake
Arh headers
Bullets
160 stat
Tune
436 whp
Old May 16, 2012 | 09:11 AM
BLEKVET's Avatar
BLEKVET
LG G6x3 cam
Comp 921 dual springs
Titanium retainers
LG headers
3-inch pipes all the way back
481 rwhp
New mods: ported and polished heads, ported intake, under drive
Will post results soon.
Old May 16, 2012 | 09:16 AM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Mods, details, and track times are in my sig. Car now has a build 3.90 rear and Mantic twin disk clutch. I expect to go 10.5 or better come winter.
Old May 16, 2012 | 10:19 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Quality Motorsports "Street Bully" cam
LG 1 3/4 Super Pro headers w/o cats
Z06 mufflers w/mod
Killer Bee w/ Beehive
Ported/polished OEM TB
Ported OEM Intake
MSD Wires
Tuned in 103 degree heat
484/446
Old May 16, 2012 | 02:25 PM
Coach G's Avatar
Coach G
Default Modified LS3
LS3 with 41K miles. Long story short:
Hiway workers left busted up concrete piled up on the side of the interstate. 18 wheeler ran through it with me behind him. I had nowhere to go but to dive thru the equivilent of a concrete "hail storm". Plenty of insurance help bought new GS wide body, ZR1 rims and brakes with huge pilots all around. I figured: "what the heck". What started out as an intake, header and tune ended up e-force 1591 with 3" pulley, Fast 65lb. injectors, Kenne Bell Boosta pump with Racetronix fuel pump harness, Custom grind blower cam (Comp cams), ported and polished heads (new Comp cams lifters, rocker arms, magnum 7.400" hardened pushrods, and Lunati Gold dual valve springs, .660" lift), ARLT coated headers, high flow cated H-pipe, stock NPPs with MtoW switch, Tuned to perfection by Brian Reckert (RPTAustin).===651 RWHP and 625 RWT. Getting 16mpg (ave) on 93 octane and having the time of my life (even when NOT in boost [8.6 psi]) BUT its not cheap and is addicting If I had it all to do over, I WOULD NOT CHANGE A THING!!!!I LOVE MY CAR!!!
Old May 16, 2012 | 02:53 PM
9157's Avatar
9157
Naples FL
Catted X Pipe
Haltech CAI
MSD Wires
160 T-Stat
Tune
i have almost the exact same set up except I have 1 7/8" Kooks.. B&B PRT's, DBA brake up grade (Z51) and Koni FSD shocks...417RWHP 406 max torque.. A6 Tune as well with COw booster...106Kmiles!
Old May 16, 2012 | 03:19 PM
LT1_E85_Corvette's Avatar
LT1_E85_Corvette
2008 M6 Base coupe
1 7/8 Kook Headers
Tune on E85
450whp
ET 11.9
MPH 122
60" on street tires - 2.1
Video
Old May 16, 2012 | 03:32 PM
robertaj's Avatar
robertaj
08 coupe
AR headers with high flow cats
base ECS kit
meth
655/630 at the wheels.
Old May 20, 2012 | 04:10 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Bump
Old May 20, 2012 | 08:19 PM
HOXXOH's Avatar
HOXXOH
'08 Coupe w/99,147 miles as of today
Vararam
LG streets
Tune
Zmax TB
Yank TC
Ported IM
Don't know or care about dyno numbers. They are meaningless if you can't put it on the pavement.
10.82 ET 126 MPH with stock IM and full Z06 exhaust system. Expecting better with the Ported IM and headers.
To Modded ls3 owners step in...
