Oil Separator/Catch Can
Old May 15, 2012 | 08:53 PM
nevillej's Avatar
nevillej
Default Oil Separator/Catch Can
Just curious who has installed a Oil Separator/Catch can under the hood and if so what have you seen regarding amount of oil captured. Is it worth doing or something that doesn't matter a whole lot.
Old May 15, 2012 | 10:19 PM
JCtx's Avatar
JCtx
Should have searched man; there're a ton of threads on the subject. In summary, the PCV valve on Vettes is crap, and it allows quite a bit of oil into the intake, whether you drive hard or not. And whether you have a dry sump or not (I do). The real debate is if it does any harm in the long run. And for roughly $200 (shipped) for the best cans out there (I used AMW), I don't want to find out the hard way . Good luck.
