Replace plugs/wires
Old May 20, 2012 | 11:00 PM
elmwoood's Avatar
elmwoood
Default Replace plugs/wires
at what milage or how many years would you change? I have a
2006 with only about 26000 miles but does time matter?
Old May 21, 2012 | 06:45 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Unless you are having spark issues or seeing visual damage of some kind I would leave well enough alone and follow the guidance set forth in the Owners Manual. For plugs its 100k miles. At 26k miles I'm sure they're fine.
Old May 21, 2012 | 07:36 AM
Don 79 TA's Avatar
Don 79 TA
i agree
only reason i changed wires/plugs was when i installed the headers, went with header studs and used the MTI wires and heat sleeving
i sold off the originals, only had 6800 miles on em and were perfect
Old May 21, 2012 | 10:43 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I wouldn't mess with them, if you had 50K miles on the car I would change them out....just because they "can" last 100k miles doesn't mean they are performing well for that entire length of time.
Old May 21, 2012 | 01:43 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
I'm always a fan of not fixing something that isnt broken. If you dont have issues then leave it alone.
Old May 21, 2012 | 09:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I had our 2001 plugs changed at 50k miles, the dealer tech said they didn't need it at that point but the ones he changes at ~100k definitely do need it.
So I plan to change 'em between 50k-75k.
Old May 22, 2012 | 08:42 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also be careful which plugs that you put into it, when the time comes to change them. At 26k miles, you are good for a long time still yet. Some of the plugs out there will generate noise on the system which can indeed cause problems for other systems you aren't expecting...such as the charging system. Trust me, its true.
Old May 22, 2012 | 09:14 AM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
This.
...and this.
To Replace plugs/wires
