Transmission cooler recommendation
Old May 22, 2012 | 11:12 AM
TKOGTO's Avatar
TKOGTO
Default Transmission cooler recommendation
I am considering one and am looking for recommendations.
I added the DeWitts rad with both EOC and TOC but a tranny seal leak caused trans temps go up 20-40 degrees while coolant and oil went down 30 and 20 degrees respectively. Saw DRM cooler for $1,300 before install but would prefer something less expensive. Any ideas?
Car is a 2010 GS, A6, Kumho XS tires, no R-compounds or slicks in the future as car is also a DD. Have ordered Amsoil ATF and some header type wrap for the lines. Fixing seal and adding better fluid and shielding will likely do the trick but considering cooler as well because I want to do this only once.
Thanks,
Terry O'
Also posted in Autocrossing & Roadracing forum
Old May 22, 2012 | 12:08 PM
dennis50nj's Avatar
dennis50nj
Thanks,
Terry O'
use a B&M or Hayden, stacked plate cooler mount bypassing the rad, less than a $100 bucks
Old May 22, 2012 | 01:01 PM
jpee's Avatar
jpee
I have one BEST one going... Be Sure it's a "STACKED PLATE TYPE !!
Old May 22, 2012 | 10:00 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The stacked plate type is supposed to be best, but I never heard why.
Can someone explain?
Old May 23, 2012 | 01:04 AM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Larger cooling surfaces, thicker material, and a design that can survive abuse without leaking or reducing airflow. If you see one in person, the advantages will be clear.
Old May 23, 2012 | 01:39 AM
C7/Z06 Man's Avatar
C7/Z06 Man
If you want the most cooling capacity run the aftermarket cooler in series with the stock trans cooler i.e. trans fluid through stock cooler to start the cooling process than through the aftermarket cooler and back to the trans.
You may get by with the one aftermarket cooler but why not use the radiator located trans cooler you already have for even more capacity.
PS: Can't hurt
Old May 23, 2012 | 02:01 AM
C7/Z06 Man's Avatar
C7/Z06 Man
The plate design is tuff, I purchased one many years ago which was made in Canada at the time. The advertisement said you could stand on the trans/oil cooler with one foot and not hurt it, so I did; well I weighed over 200 than and no damage what so ever. Cooler is still on my 9 second street 87 Buick.
Old May 23, 2012 | 10:24 AM
dennis50nj's Avatar
dennis50nj
PS: Can't hurt
ok l have tried both, independent produced lower temps not just trans but also water
Old May 23, 2012 | 11:05 AM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
PS: Can't hurt
I'm actually considering doing just the opposite. In 110 degree weather here in Phoenix, I have to drive 20 minutes in traffic with my 3600 converter just to get trans temps above 150. On the freeway with the converter locked it never gets up to working temps.
I'd like to find a way to control it, so it would automatically hold temps in the 160-180 range. Maybe running through the radiator first will heat it enough that the Hayden won't cool it too much.
Old May 23, 2012 | 11:15 AM
jthurik's Avatar
jthurik
Use the B&M with a Fan and remove and put it behind the fog light.
Old May 23, 2012 | 12:13 PM
C7/Z06 Man's Avatar
C7/Z06 Man
If the cooler with its own fan or not is large enough to keep the trans temp to low, say less than 150 than running it through the stock cooler will warm the fluid and "maybe" help lower the water temp/engine temp also.
If you think about it, running the fluid through both coolers should help to stabilize both engine and trans temps better. Stability means reliability and/or a more consistence repeatable performance.
PS: But if the $hit ever hits the fan you will still have more cooling capacity with two coolers than just the one to keep the temp out of the red zone. Is this a Goldy Locks story or what???
Old May 23, 2012 | 12:35 PM
Gearhead Jim
St. Jude Donor '13
I've also wondered about the idea of bypassing the radiator, or not (my car is totally stock now).
Part of the problem is, we don't know what trans temp is best.
Anything over 230 is definitely warmer than desired, but what about min temp?
I'm guessing that a constant 190' would be close to optimum, and anything less than 150' is getting too cool. But those are just semi-educated guesses.
Old May 23, 2012 | 12:54 PM
HOXXOH's Avatar
HOXXOH
I was originally trying to take some load off the radiator, but it appears like the tranny was helping cool the engine instead of just itself. I understand why the stock arrangement works well for most circumstances, but the high stall converter heat complicates finding the new happy operating range.
I'm not using a dedicated fan on the cooler, but I do have it mounted in a non-traditional method and location.
It makes me wonder about a stacked plate design for engine coolant. Hmmm.
Old May 23, 2012 | 12:59 PM
jthurik's Avatar
jthurik
add the fan, I did not and I am going back and adding it even in 90 degree weather when I am driving 60 it will cool never over 171 even with some pulls but in stop and go traffic you will want the cooler. I run a 3500 stall and trust me I want the fan... The cooler the tranny stays the longer it will live you and always turn the fan on and off and it will be great for track days to cool it down in between runs.
Old May 23, 2012 | 01:22 PM
HOXXOH's Avatar
HOXXOH
I think your guesses are pretty good. According to some prominant transmission builders and re-builders, the failure rate curve starts moving up exponentially around 175 degrees and goes nearly vertical by 260. They also say 150 is the low limit for proper operation.
I'd like to be able to control it to remain in the 160-180 range. So far, I have no problem keeping it cool, but getting warm without being too hot is my issue. The variables of ambiant air temps, air flow, gear selection, and transmission load, make it difficult. An internal transmission thermostat would solve the problem, but at this point I'm just glad to know what temperatures exist.
Old May 23, 2012 | 01:40 PM
el es tu's Avatar
el es tu
ive wondered about this as well.
Ive been toying with the idea of running 2 z06 oil coolers (one for the engine and one for trans)and putting the trans one behind the engine oil cooler to help with warmup while having it also tied to the radiator trans "cooler"/warmer. This should help cool the trans when it gets hot, while keeping it warm in cooler climates
Old May 23, 2012 | 01:42 PM
HOXXOH's Avatar
HOXXOH
My problem is not cooling, it's not being able to get up to a normal operating temperature.
Track days are a major issue. I sit in the staging lane in gear, hoping to get up to 140+ before a pass.
If you've ever gone WOT through the gears with the A6 under 130 degrees, you'll know the problem.
I'd put tape over the cooler to stop some airflow, but that creates engine coolant issues.
I'm going to try routing fluid through the radiator, both before and after the cooler to see what works best.
To Transmission cooler recommendation
Old May 23, 2012 | 02:32 PM
Gearhead Jim
St. Jude Donor '13
Please post your numbers, Enquiring Minds Want to Know!
Old May 23, 2012 | 02:39 PM
Gearhead Jim
St. Jude Donor '13
Just to complicate your plan a little, we usually don't know what the water temp is in the radiator tank that holds the tranny cooler. When my coolant gauge first hits 190' (stock thermostat), there is not much water flowing through the radiator and that tank will be pretty chilly especially during a Chicago winter. But after cruising at 75 mph on the Interstate on a summer day, the "official" water temp is still 190' but I'd bet the radiator tank is much warmer than in winter.
And your situation will be different from mine.
Old May 23, 2012 | 02:44 PM
Don 79 TA's Avatar
Don 79 TA
there are also thermal switches for the coolers as well
perhaps that helps
