07 C6 Automatic convertible top troubles.
Specifically, the striker for the tonneau cover is not lowering, it's staying in the up position whether completely raising or lowering the top. I've checked the fuses and there fine. From the research I've done on the site, and others so far this leads me to either the folding cover pull down actuator or the BCM/TCM not working correctly. I'm getting no messages on the dash and there are no other problems with the tops function. Just that last little inch that the cover pulls down when the operation is complete. Does anyone have an idea how to distinguish whether the problem is with the actuator or one of the control modules?
Any and all help you all can provide would be greatly appreciated.
I'll see if I can post pictures later.
The Bull Gear in the actuator was missing a few teeth. Easy fix. Hear is a few more pictures for detail.
This is the group of limit switches that bolt to the actuator housing
This is the pull down striker itself. The part your tonneau latches to.
So I started looking around to replace the gear. Not as easy. The entire accuator is easy enough to find, but costs between $200 to $400. I found one used on ebay for $114.00 out of a 05 C6. So more research was in order. Turns out GM has been using this part on cars including Caddilacs, Buicks, and Chevy's since the late 1980's. Here's a link to the part made by AC DELCO
http://www.rockauto.com/catalog/x,ca...2Bfor%2BDORMAN
I think that's still a stupid amount of money to replace a gear.
I checked Ebay.. There's plenty of people making this gear and selling it as a Cadillac/ or Cammaro component, (it works, I crossed referenced the parts)
Here's a search I used:
http://www.ebay.com/sch/i.html?_nkw=...&_osacat=33648
I've read on our forum's here that other folks have fought tooth and nail with their dealerships and repair shops, either trying to figure the problem out or the dealership/ mechanic charging $400+ dollars to fix this issue by replacing the entire actuator. I found the gear sells for between 5 and 12 bucks. It take 15 minutes or so to remove your waterfall, (search under C6 tech forum for waterfall removal) and the pull down actuator unbolts from the mount with three bolts. It would be a good idea to pull the 20 amp TPA fuse in your BCM fuse panel (the one at the feet area on the passenger side), while you perform this repair. Make sure when you put the actuator back together to screw the new gear down the threads of the striker such that the tabs on the side of the striker are straddling the smaller limit switch on the switch group. You don't want the switch either above the top tab or below the bottom one. Run your seats all the way forward and lean them to the dash to give yourself ample work area. Use clean rags to cover your work area because it's likely a little grease will end up on your fingers and you don't want that staining your interior. If anyone has any other questions about this subject I've become an expert lately, pm me if you have questions. Happy cruising !!!
-Litofeit
https://fbcdn-sphotos-b-a.akamaihd.n...53668341_n.jpg
I do remember thatI replaced the whole unit and it has worked fine ever since.
Good luck
PArt number 20160587 is the gear and cost a whooping 7.00. I discovered my housing was in about 3 pieces so I tracked down a housing since the complete unit runs 200.00 for the cheap one to over 400.00 for a GM model.
I located this
Which is an exact match to the GM unit. For 46.00 and it comes with the gear as well. I gave it a shot and it works great.
I'll be listing an extra gear for sale soon.
If the tonneau is not latching and closing could very well be the gear4 inside the assembly being stripped or broken. Best bet is to remove the waterfall and take a look. Usually this symptom is the motor constantly running.
Does the top cycle all the way till the tonneau is almost closed then not latching and pulling down? Just replacing parts will get expensive.
-Litofeit
