06 Vette Automatic Trans Lag?
Old May 24, 2012 | 01:27 PM
bartsky's Avatar
bartsky
Default 06 Vette Automatic Trans Lag?
Hey guys, I have an 06 automatic coupe with 64k miles that takes took much time when going from Park to Drive, then clunks in. Has anyone else had this problem? Thanks...
Old May 24, 2012 | 04:41 PM
cryoman07's Avatar
cryoman07
Having this problem myself
Old May 24, 2012 | 10:48 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I believe there is a TSB about the slow shift into Drive (sometimes called a Garage Shift), and some other shifting issues. The fix was not easy, if you really had the problem.
Old May 25, 2012 | 05:49 PM
Ragtop 99's Avatar
Ragtop 99
How's the fluid level and condition? That's an easy first place to start.
Old May 25, 2012 | 07:55 PM
Gering's Avatar
Gering
Tolero Apto Victum
Drain / drop pan / install new filter / clean pan / inspect gasket / refill. Dirty oil and high temps degrade transmission performance. I do the above every 30K miles.
To 06 Vette Automatic Trans Lag?
