A/C not working.
Old May 28, 2012 | 12:26 AM
MikeSVT04's Avatar
MikeSVT04
Default A/C not working.
tried the A/C today for the first time after my cam install and no dice. Just blows air. The compressor isn't even kicking on.
I figured it was due to the high heat/coolant pressure shut off, but I didn't work at night wither cooler temps.
any Ideas or simple fixes?
thanks
Mike
Old May 28, 2012 | 12:53 AM
ChevyDave's Avatar
ChevyDave
i'd think some connection become loose/unpulgged. sure you already checked that. there is fuses..
http://www.chevrolet.com/assets/pdf/...ble_owners.pdf
kick panel page 6-103
engine fuse block page 6-106
you can try a reset, doubt is will work but costs nothing... Hold down the "Fan Speed", "Windshield Defrost" & "Rear Window Defrost" buttons on the HVAC head unit simultaneously for about 3 seconds.
Old May 28, 2012 | 09:45 AM
MikeSVT04's Avatar
MikeSVT04
haven't checked all the connections. anyone have a pic on where I should look. Im a noob with wiring.
edit: checked all A/C fuses. They all look ok.
Old May 28, 2012 | 12:10 PM
Streetk14's Avatar
Streetk14
Couple stupid questions for you:
1- were any lines to the condensor disconnected during the cam swap? On these cars, you either have to remove the condensor, or hang it up out of the way. I did that very thing on my cam swap, but it can bend or damage the A/C lines. If it was completely removed, was the system re-charged?
2- Are the pressure switch and compressor clutch plugged in (pressure switch is on right fender area, screwed into A/C line) ?
I'm guessing the charge is low or something is unplugged....
Old May 28, 2012 | 12:27 PM
MikeSVT04's Avatar
MikeSVT04
^^^idk. I had IPS motorsports do the install. I am going to go to them to look at it. I just wanted to make sure this didn't sound like a boken A/C unit.
I figured a something is disconected or not enough freon charge.
if there isn't enough freon will the compressor not kick on?
To A/C not working.
