Can someone please help identify these wires
Old Jun 2, 2012 | 06:24 PM
slvrc6z51's Avatar
slvrc6z51
Default Can someone please help identify these wires
i had to repair some wiring in the r/f of my 2006. the harness has the headlight ,side marker,foglamp,airbag sensor,hood light and horn connectors. after going into the harness where the foglight wires come out, i found a green and yellow thin gauge wire cut. i have no idea what they are for. i have attached 2 pictures with the wires labeled..im not sure if they are for a outside temp sensor or what..any help would be greatly appreciated!
Old Jun 2, 2012 | 07:46 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Yellow may go to/toward speed sensor and Green may be to the fan speed controller.
Best my book shows.
Old Jun 2, 2012 | 11:22 PM
slvrc6z51's Avatar
slvrc6z51
thank you..i will check tomorrow..
Old Jun 3, 2012 | 03:37 PM
Bill Dearborn's Avatar
Bill Dearborn
Several of the connector end views from that area show Dark Green and Yellow wires in the same harness. C186 for early C6s and X186 for later ones shows both wires in the same harness. Look at the attachment and see if that lines up with what you have.
Bill
Old Jun 4, 2012 | 10:38 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Other than what I posted I cannot seem to find a schematic that shows the front wiring harness. The pinout would indicate that the green is going to the fan module and the yellow is going to the right wheel speed sensor. Nothing else in that area is using those colors.
To Can someone please help identify these wires
By Michael S. Palmer | 2026-06-03 09:39:05
