05 c6 reduced engine power ..help ???
Old Jun 4, 2012 | 09:01 AM
yellow05z51's Avatar
yellow05z51
Cruising
Default 05 c6 reduced engine power ..help ???
can drive down the road and it will cut off and say reduced engine power...pull a few relays and put back in or disconnect battery and it may crank back up and it seems to have a misfire (reduced power) ...ive touched both battery cables for 20 seconds ..didnt seem to help..any more help would be great
Old Jun 4, 2012 | 11:28 AM
NORTY's Avatar
NORTY
Overheating?
Old Jun 4, 2012 | 12:02 PM
yellow05z51
Cruising
no..went to parts store..code is saying cam sensor so im doing that right now..
Old Jun 4, 2012 | 01:03 PM
yellow05z51
Cruising
ok just took out cam shaft sensor and its pretty worn down on it kinda like something hott made an indention on it for about 3mm inside so i have new one be here tomorro ..just would like to figure out what made it wear down like that..05 20k miles
Old Jun 4, 2012 | 02:36 PM
taken19's Avatar
taken19
Track Junky
Good luck finding the cause. You sure you used loctite on the cam bolts? Nothing should be close enough to hit the cam sensor in there...
Old Jun 4, 2012 | 04:14 PM
yellow05z51
Cruising
its all stock
Old Jun 7, 2012 | 10:53 AM
Doo1ooM's Avatar
Doo1ooM
Cruising
check ur map sensor i had the same issue before
To 05 c6 reduced engine power ..help ???
