Which car is easier to launch with all things being equal, the C5z06 or a C6/M6? I have heard that both cars are prone to wheel hop upon hard launches but nothing like my GTO. I do plan on taking the car to the drag strip and smashing an occasional 5.0 in the meantime, but I want the car that is easiest to launch…this GTO is a pain to launch its always a tossup depending on the surface of the road.
My GTO had no wheelhop. It also had a great deal of suspension work. It had a lot with the factory stuff.
My C6 has very little. It has non-runflats and different shocks/sways. It had a lot with the factory stuff.
My C5 had a lot with stock tires and suspension. Same with the C4. Guess what...improved with aftermarket tires and suspension.
Takeaway: all IRS cars are difficult to launch. If you want to get them to go consistently out of the hole, you need to have either A) Ranger's gift, or B) Better equipment than OE.
All manual trans cars, are more subject to driver control; than an automatic.
My GS is tempermental on surface texture in regards to wheel hop.
How can anybody answer your question?
Easy with all things being equal which car is easier to launch the C5z06 or a C6/M6? Maybe I should have added each in stock trim.
It would be good to hear different experiences from corvette owners who have driven both; however it would also be good to hear launch experiences from the C6 vette owners.
TNTC4VETTE helped a little by giving some of his experience and helping a future vette owner know that these things can be a handful to launch like my GTO in stock trim.
I've had both a c5 and a c6 convertible manual.
They launch equally well with virtually no wheel hop....the key being drag radials. With drag radials at 17 psi they launch and go.
I never launched either very hard with street tires, spinning tires is no fun.
I had a 2002 Z06 and I now have a 2006 C6 Z51 M6. I took my C5 Z06 down the track about 40 times all on street tires. It would wheel hop in first and second gear no matter the air pressure. I have taken my C6 down the track maybe 15 times with the same result.
I have to believe Joe is right on the Drag Radials and I would bet TNTC4Vette is correct with regard to suspension upgrades as my 05 GTO had bad wheel hop until I put Hotchkis sway bars on which is all it too to eliminate the issue for me on that car.
So either way you go you are going to have to have to either get DR's or suspension upgrades with non run flat tires.
the newer c6 manuals (2009 or 2010 and up) get launch control... my money would be on the c6
Joe is a great driver. He figures out what HE did wrong and improves.
I am a human excuse generator. I figure out what part is "causing" my problem and replace it.
GTO had big bore shocks, aftermarket springs, sways, drag radials, and drag bags. It still never matched a decent ET to the traps it ran. Barely in the 10s at 139mph...and most of the mph was from 660' on.
The C6 was abysmal on the MPS2s in stock sizes. It was much better after the JOC suspension and NT05s.
You didn't say manual or auto; that makes a difference too. And if you want to get rid of your GTO just for that issue, it'd be infinitely cheaper to upgrade your bushings (at the very least) with Pedders, and Hotchkiss sways. And that alone would transform your car. Finally, I personally don't plan to ever launch my new GS because I don't plan to upgrade anything either, but newer cars ('11+, I believe) have 'launch control'. How much that helps I don't know. I'd also imagine the GS should be able to launch better due to better grip (wider tires, and/or stickier, at least with the manual versions). A LOT depends on the driver as well, so forget about getting a clear-cut answer on a forum. Good luck.
TNTvette thanks for the kind words! I do like to optimize my driving as opposed to spending my way to fast.
Launch control, in my observations at the drag strip, is completely useless. 2.3 60 foots, and a couple were wheel hopping! I think Kerrdogg has it, see what he says. I know for a fact he doesn't use it.
My next track event will have many surprises for me, I am going to make my first run with 100 more rwhp and on new tires ( RE-11's ) my dilemma is: do I install new tranny mounts first? Won't matter as I do not get to practice enough to worry about the poor times I am going to put down lol
Now if Joe would ever come back home while Gateway is still open, I might get him to teach me a thing or two?
^^^should be there in July...be happy to tell you what I know. My advice is don't spend any money on mounts, get some drag radials....otherwise you won't be happy.
My rear end started to whine after installing the Hinson mounts(at least I think/hope that's the case). I'll most likely be removing them and replacing the stock mounts very soon. I was able to go consistent 1.5s and a 1.48 on stock tranny mounts..I'm not really sure why I changed them out.
Flying or driving? Beers are on me Joe if you can spare a couple hours while in town.
I won't be able to pull the trigger on rear wheels and DR's, replacing my Invo's that have 20,000 miles on them with the RE 11's is the only upgrade in the budget in that price range.
I appreciate all the feedback on the mounts as I'm sure others do that are following this thread.
You can count on it...I won't have my car but I'll have wheels. My friend in St. L just bought a c6 so I'll con him into heading over. Let's stay in touch in the next few weeks.
Sure wish you could borrow some drag radials...I have to think if I know anyone with some...it's like night and day.
Wagon wheels are cheap - I gave my set away or I'd give them to you. Heck I'd tote my DR's up and lend them to you but mine won't fit on your car, 315's rub on a standard c6.
I will ask around to see if anyone has a set of DR's.
C5 setups will be fine or even F-body setups. You're looking for some 275/40/17 Mickeys. Hopefully tires that aren't more than 4 years old, they get slippery as they get old.
My experience is that a lower geared transmission is easier to launch then a high geared one. The C5Z06 has the lower gearing that the C6 Z51 has and the C6 GS has. The base C6 has higher gearing.
