6l80 issues
Old Oct 4, 2012 | 08:27 PM
fettvette's Avatar
fettvette
2nd Gear
Originally Posted by Badd LS6
might potentially have cam bolts backing out..getting a rattling noise when i rev the car up to 2000-2500..and have the cam position code..today after leaving speed inc, i stopped at the gas station..tried starting the car up and it wouldn't start..cranked for 3-4 seconds..i stopped it and tried again and it started up..than did the same thing when i got home..
Put the car on the lift and could barely see the sensor.. Just gonna have to bring it into speed inc to tear everything apart and inspect the cam bolts..
Did you figure out the rattle problem and no start up? I have a 05 that will start fine then sometimes wont start turns over but you have to hit the button to stop starter?
Old Oct 5, 2012 | 09:25 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
fettvette,
I'm sorry you are having these issues. Have you taken your Corvette into your friendly neighborhood dealership to have your problems checked out?
Evan, Chevrolet Customer Service
Old Oct 5, 2012 | 09:41 AM
fettvette's Avatar
fettvette
2nd Gear
I have. They replaced Fuel pump,Ecu and put a new belt on it. I held a straight edge from the crack to the other pulleys and it looks that it is slid out I feel the crank bolt came loose. Will that make it just crank and no start due to the crank sensor
Old Oct 5, 2012 | 10:04 AM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
His motor blew and fused a lifter into the black. Complete rebuild was necessary, we're about to put the motor back in then we have to figure out the trans issue. Hopefully a smaller stall with fix it.
Old Oct 6, 2012 | 03:00 PM
Le Mans Z06's Avatar
Le Mans Z06
I had a P0716 code as well and it put the car into limp mode. I couldn't find much info on here either. I was told by a member here with a built A6 to clear it and see if it comes back it should be okay. I haven't seen it come up again but I really haven't driven the car much due to non-trans related issues. Matt @ ECS never got back to me on the code though so I'm not really sure if it's something to worry about. Hopefully it's something minor.
Originally Posted by subfloor@centurytrans
If you're running NGK plugs they might be the issue because believe it or not (and this came directly from a tech at NGK) they can cause havoc on your electrical system including the TCM.
As for the NGK plugs, has anyone ran into any issues running them?
Old Oct 8, 2012 | 09:36 AM
Atomic C6's Avatar
Atomic C6
Btw Matt is no longer with ECS call Doug or Chris. The 6L80 can be a bear good luck. I would not ignore it.
Old Oct 8, 2012 | 09:42 AM
Le Mans Z06
Thanks, a member here had the same issue and cleared it and it never became an issue so I'm hoping it's nothing major. I will bring it to their attention though.
Old Oct 8, 2012 | 11:29 AM
Rev Xtreme's Avatar
Rev Xtreme
St. Jude Donor '13
Hey bud.. Yes I am no longer with ECS as of a few months ago. If you email matt@eastcoastsupercharging.com it should forward over to the general mailbox. For best reply call Doug or Chris at 609-752-0321 or you can email Chris@eastcoastsupercharging.com.
Matt
Old Oct 8, 2012 | 04:35 PM
Badd LS6's Avatar
Badd LS6
The no start was from the cam position sensor getting eaten alive by the cam gear..I had cam bolts backing out that destroyed bunch of lifters from the cam floating..I had a lifter stuck in the bore that had to come out from the bottom..lifter bore was tore up pretty good..was also getting piston to valve smack..ended up getting a deal on a trade plus cash for a rebuilt short block..
New vs old Cam position sensors
Oil pan treasure
Old Oct 24, 2012 | 02:41 AM
Badd LS6's Avatar
Badd LS6
Any info out there on the PO716 code? My car should be out and about again by the end of this week.. And I still have yet to solve the trans problem..my buddy has a Scanner that can delete the code and hopefully that resolves the problem.
