C6 rear tire off size question
Old Jun 12, 2012 | 03:19 PM
ShaWING66's Avatar
ShaWING66
Default C6 rear tire off size question
I read that you can mount 275 width tires on the back of a reg c6. I want to either mount nitto nt-05, michelin super sport, or vredestein sessantas which only come in 275 35 19 (except the nt-05s, i think). I have super sports on the front and love them and firestone wideovals in the back.
Can i do this? Any suggestions?
Old Jun 12, 2012 | 06:53 PM
haljensen's Avatar
haljensen
You probably can mount 275mm tires in the rear but they'll have to be much taller than a 35 aspect ratio. The front and rear tires have specific different diameters that have to be maintained to keep the computers happy. You have to stay VERY CLOSE to original diameters.
Go to; http://www.1010TiresizeCalculator.asp and enter your stock sizes to get a diameter then find a correct sized 275mm tire of a brand you want.
Old Jun 12, 2012 | 07:30 PM
Paul71LT1's Avatar
Paul71LT1
FYI, my 2008 Z51 equipped "regular C6" came from the factory with 285's, but I think the wheel is taller, being 19 inches and your's is likely 18 inches if not a Z51. The 275 width should fit but as the previous post cautions you have to watch the height or the ABS/ASR sensors won't be happy. Also will fiddle with speedo accuracy.
Old Jun 12, 2012 | 08:29 PM
ShaWING66's Avatar
ShaWING66
Thanks for the heads up, but i have a z51 too
Old Jun 13, 2012 | 12:28 AM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
The PSS comes in 255/40-18 and 295/35-19, so just a little larger than OEM both front and rear. Those are the sizes I was going use, and if not, then I'd go with a PSS up front and a PS2 in back in OEM sizes.
Old Jun 13, 2012 | 11:36 AM
ShaWING66's Avatar
ShaWING66
It looks like 295/35-19s are harder to come by and 295/30-19s are a little too far off.
the 275/35-19s are only 1% off on circumference and significantly cheaper than 295s.
Any other input?
Old Jul 10, 2012 | 02:44 PM
ShaWING66's Avatar
ShaWING66
I keep seeing that the Firehawk wideovals are classified as "ultra high performance" apposed to "max performance", which is why I'm going for the 275/35R19 Vredestein Ultrac Sessanta which are about $450 a pair shipped. Cant beat that. (Also the circumference difference is only 1%)
Has anyone tried this?
Old Jul 10, 2012 | 06:28 PM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
Why run those narrower tires then what factory used.
Do a 305/30/19 on the rear.
I have hankook ventus v12 on mine. Alot of people run this tire i love them. Nice tire at a good price
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old Jul 10, 2012 | 09:37 PM
timd38's Avatar
timd38
I did Michelin Super Sports in 305/30 19 on the rear with 10.5" wide BBS wheels. Fit and look fine.
Old Jul 14, 2012 | 09:34 PM
ShaWING66's Avatar
ShaWING66
I think im going to stay away from the Ventus... they get good ratings but not the level im looking for.
I read the 305s are meant for 10.5-11.5 inch wide rims... will they work on the 10s?
Old Jul 14, 2012 | 11:09 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
They will work on 10's but I found the rear swayed under hard acceleration. Now that I put them on 11 inch rims, the swaying is gone and the 305 PSS tires work great.
Old Jul 15, 2012 | 11:05 AM
ShaWING66's Avatar
ShaWING66
Thanks for the input. I think ill take the 275/35 route at $450 for a pair of vredesteins over buying a set of rims and a $900 pair of PSS's (though they are great tires).
Cheers!
To C6 rear tire off size question
