08 C6 A6 Trans supply/return line identification
2 - Summit 220649 6AN to 1/2" NPT threads
2 - Summit 220687 6AN 90 degree end swivel
2 - Summit 220690 6AN hose end straight
1 - Summit 230606 stainless steel braided hose - 6 ft.
1 - Dorman 800-605 fitting (available at your local parts house)
1 pkg. 12055 from Pure Choice Motorsports - you will use only 1 fitting if you run your cooler in series
1 - Russell 640830 M16 x 1.5 to -6AN flare fitting.
1 - B&M 80278 mounting kit
2 -1 1/8 x7/8" grommets - Lowes (you'll need to make 2 holes in the side of your shroud for your cooler lines). I used my Dremel tool for this.
I have a 70266 B&M cooler and it keeps the temps in check. No problem.
Good luck
