Ported intake manifold dyno results
Old Jun 22, 2012 | 02:24 PM
peakspeedshop's Avatar
0peakspeedshop
Former Vendor
Default Ported intake manifold dyno results
We just received dyno results and this note from Barry at Jerry's Chevrolet Corvette Center in South Dakota. They installed the Radically Ported Intake Manifold and Ported Throttle Body from Peak Speed Shop and are thrilled with the results. We love getting the before/after dyno reports from shops like this because they reflect non-biased results of our work. Take a look.....
Bob - Peak Speed Shop
Order from our website at : http://www.peakspeedshop.com/
Bob,
It’s been awhile since we spoke but I wanted to share with you the results of the installation of your radically ported LS7 Intake and Throttle Body. Attached is a dyno sheet showing before and after results of installing your radically ported intake and ported throttle body. I want to tell you that this car is a 2009 Corvette Z06 with long tube headers, a performance air filter, performance camshaft and OEM mufflers – It has been dyno tuned before the installation of your parts. It is running 92 octane pump gasoline. The before and after results show only the addition of your parts – we didn’t do any tuning to influence the results. The gains were very similar to your estimates. Peak power rose 15.74HP and peak torque went up 10.67 ft/ lbs at the rear wheels. What is more impressive than the peak numbers is the fact that the power gains were much larger in the lower RPM range. Take a look at the graph at 3500 RPM – before the ported intake and throttle body the power levels dipped a bit as the cam “started to come into its own”. With the ported intake and throttle body installed the power levels do not dip at all and gain close to 30 ft/ lbs of torque and 20 HP at the rear wheels! To say the least I am very impressed by your products and service.
Thank you.
Barry Konken
Jerry’s Chevrolet
Corvette Center
Beresford, SD
Last edited by peakspeedshop; Aug 1, 2012 at 11:52 PM. Reason: changed dyno graph from bmp to jpeg format; added website for ordering
Old Jun 22, 2012 | 03:38 PM
Random84's Avatar
Random84
That's impressive.
Old Jun 25, 2012 | 11:25 AM
AtomicBob's Avatar
AtomicBob
So how about after tuning?
Old Jun 25, 2012 | 05:17 PM
0peakspeedshop
Former Vendor
If we can get copies of those results, we'll post those, too.
Old Jun 25, 2012 | 05:38 PM
dvandentop's Avatar
dvandentop
awesome nice to see some good gains.
will possibly be heading your way for some work.
Old Jun 25, 2012 | 10:30 PM
dovervold's Avatar
dovervold
Very nice! I have the same package with cam and headers and stock intake. Will be keeping an eye on this thread, and probably headed your way as well,
Old Jun 27, 2012 | 01:11 PM
AtomicBob's Avatar
AtomicBob
Did this car get tuned...? Or did they slap this stuff on and leave it alone
Old Jun 27, 2012 | 04:57 PM
0peakspeedshop
Former Vendor
No, it was tuned after this dyno test. If I can get copies of the dyno results after tuning, I'll post them. Tuning should make the results look even better.
Old Jul 2, 2012 | 02:49 PM
0peakspeedshop
Former Vendor
ttt
Old Jul 5, 2012 | 07:19 PM
0peakspeedshop
Former Vendor
Some members said they couldn't read the dyno graph. Just changed format from bmp file to jpeg. Let me know if anyone still has a hard time reading the dyno graph.
Old Jul 10, 2012 | 07:10 PM
0peakspeedshop
Former Vendor
ttt
Old Jul 11, 2012 | 02:44 AM
HC Mechanic's Avatar
HC Mechanic
I love when shops leave the smoothing of the Dyno graph at 1.... Ha Ha
Looks like a great mod though
Old Jul 11, 2012 | 05:43 AM
SpinMonster's Avatar
SpinMonster
Bob,
Thank you.
Barry Konken
Jerry’s Chevrolet
Corvette Center
Beresford, SD
Whats really interesting is that this makes a case for airflow demand in the front of the engine with deep breathing cams. I'd imagine that the extra reserve air from the posts in the manifold being removed does in fact matter.
Great result Bob. Who trained you in porting?
Old Jul 11, 2012 | 10:02 AM
0peakspeedshop
Former Vendor
I went through extensive training by one of the best in the business. I'm trying to recall his name.... it was "Spin" something....
Old Jul 16, 2012 | 05:37 PM
0peakspeedshop
Former Vendor
ttt
Old Jul 30, 2012 | 01:00 PM
0peakspeedshop
Former Vendor
ttt
Old Aug 1, 2012 | 11:55 PM
0peakspeedshop
Former Vendor
Default Peak Speed Shop ordering info
Some have inquired how to order porting work from Peak Speed Shop. Here is our website for placing orders: http://www.peakspeedshop.com/
To Ported intake manifold dyno results
Old Aug 2, 2012 | 12:11 PM
LEAVINU's Avatar
LEAVINU
What's the purpose of the "post" that are removed during the radical port job? I've never understood why they were there in the first place.
Old Aug 2, 2012 | 01:42 PM
0peakspeedshop
Former Vendor
When the manifold is constructed it is made of three pieces and sonic welded together. The posts help line up the three parts when they are assembled. They also help reduce resonance. So, removing them may cause the manifold to resonate more engine noise. Most customers don't notice or mind a change in resonance if they can gain more horsepower without them.
Old Aug 2, 2012 | 03:00 PM
0peakspeedshop
Former Vendor
Default Check out our new online store!
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
