Garage door opener
Old Jul 10, 2012 | 06:00 PM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Default Garage door opener
I am trying to pair my garage remote door opener with my 05 but having no luck. I went by car owner’s manual step by step. I have a Chamberlain door opener. Have anyone had any luck with his type system.
Old Jul 10, 2012 | 07:23 PM
ChevyDave's Avatar
ChevyDave
note: if your opener hand controler doesnt use dip switches in it, you can totally ignore my post, also i have a 2011 so they may have changed the 'homelink transmitter'
i dont know that opener but in case its like mine, here is what i wrote and placed into my manual. my manual was wrong or at least incorrect in a way that messed you all up.
press 1&3 2-3 seconds
press 1&2&3 3-4 seconds
(lights blink quickly)
press 1&2&3 2-3 seconds
(lights blick slowly indicating ready for programming)
do dip setting presses opposite until done
press 1&2&3 2 seconds
(all lights on)
choose button you want to be opener and press it
(done)
the only part i aint sure about is where i wrote 'do dip setting presses opposite until done'.
i have to assume that the book indicates it all backwards or something. its been over a year since i made that note.. lol memory fails
i know i opened up the manual clicker and read the dip settings in it, wrote them down, and later figured i was pressing the settings totally backwards
good luck, again i dont know if yours is like mine , but above is what i had to do
Old Jul 10, 2012 | 09:05 PM
cclive's Avatar
cclive
If it is a Chamberlain that is newer (the remote will say "SECURITY+") then it definitely can be done. In an '05, you have the Homelink system. They have a very good helpline and can walk you through it. Look in your owners manual for the 800 number for Homelink.
Old Jul 10, 2012 | 10:32 PM
Z06-HEC*'s Avatar
Z06-HEC*
Edit: sorry i have no clue what my opener is, but the manual calls for touching the memory button on back, i did not have to do that as I describe below.
i did my 06 today....
press 1 and 3 until it is blinking fast, that erases any previously programmed codes.
press the button you want to program, i programmed 1, until it is flashing slowly, about 30 seconds. ready to program
press the already programmed garage opener while holding your car button(button 1 in my case) and once the light is flashing fast that means it took the code.
thats all i did and it worked, i can open and close now from the vette.
To Garage door opener
