I just finished up the nitrous install, battery relocation, and a few other small projects and I knew my battery was dead so I pulled the wifes Honda Civic next to the car to jump it off, and this is the result. . .
Is this what happens when the battery is dead or did I wire up the battery relocation incorrectly? I had jumper cables attached to both cars for well over 30 minutes and the car still only clicks. In my 29 years, I've never had a dead battery so this is a new one to me. If in fact it is dead and I can't use the Honda to jump it off. . .what am I to do? I feel like it should have enough juice to at least attempt to start but it just clicks and that worries me.
...or did I wire up the battery relocation incorrectly?
That remains to be seen, but first you need a known-good battery. A 30-minute jump on a discharged battery isn't going to do the trick. Time for a new one.
It's a small battery that worked perfectly a few days ago before I started on the project. I actually forgot to unhook it the first night and I left both doors and the hatch open. The next morning i realized it and saw that it was dead. I got done with everything today and went jump it off and the clicking is all I got.
I highly doubt the battery died but I didnt know if it could take a long time to have enough juice to fire the starter.
I relocated the battery to the hatch and used 1 gauge wire to run the positive back to cubby. I also used 1 gauge battery to ground the battery on the frame and 1 more piece of 1 gauge to ground the negative terminal near the fuse box.
Can you throw a new good battery on it? It should start then.
You may have ruined that tiny battery I'm afraid.
Two things. You should get a battery charger and try to charge it...can you borrow one?
Also I highly recommend you invest in some really good jumper cables...1 or 0 gauge wire, the best you can afford. I can't tell you how many times I've been able to jump a car when others have failed, because I have good cables. Believe it or not, WalMart used to carry really good ones. I have a set that's 10 years old or more, they are great.
Could a complete discharge ruin a battery like that? It's been perfect since I got it up until tonight. If I take it to autozone, can they test it? Or is it possible it still shows as good but in fact its toast.
It could very well have ruined it I'm sorry to say. I hope not.
You could have autozone test it but I've never had much luck with those tests. If you can get it on a charger that would be the best plan. Too bad you're so far you could borrow mine.
Oh and a safety issue I'll share...I learned this the hard way.
Always hook up a battery charger first, then plug it in. When you take it off unplug it first before removing the clips. If you unhook the clips first it'll spark...and charging batteries produce hydrogen. Not a good combination if you want to keep your eyebrows.
Would swapping in Melissa's battery prove anything? I feel like having the jumper cables hooked up from my battery to her car would accomplish the same thing. Is that not the case?
Yep. Try it. Talking from experience here.
Thin cables cannot carry enough amperage to get a really dead battery going. Takes great cables to do that.
Went to Walmart and bought a battery tender/charger and plugged it in tonight. It had 225 reviews and 4.5/5 stars so if the battery has hope, I should know in the morning. If it is in fact KIA then I'll take this as a lesson learned and go buy another one from autozone.
After letting the battery charge overnight and through the work day, the car fired up with no problems. I did not have to buy a new battery, only a $20 trickle charger
I also need to not leave the doors open with the battery still hooked up. Walmart had some 2 gauge cables but that was it. Think that will be ok?
Yep. My set came from there, they came in a circular bag that fits behind the seat and they work great. Better get a set for the wife too. I have a set in all cars and I've used them. Usually for other people but good to have.
Leaving the doors open probably didn't cause the problem. The BCM shuts everything down after 15 minutes. I do this all the time when working on my car and the battery isn't affected. If you were constantly closing and opening the doors then you could run it down.
I suspect you might have turned the ignition on and didn't get the car completely shut down although if the engine isn't running and the ignition is left on the system shuts down the ignition system but leaves such things as the back up lights on.
When you moved the battery the other thing you did was increase overall starting circuit resistance even though you used a heavy gauge wire. With the increased resistance the battery voltage can't drop as low as it could when mounted in the stock position.
Good info Bill. Thanks for sharing. I had a lot going on and it's possible that it was a combination of things that ultimately drained the little baby battery completely down. Before I started working on it, I was on vacation and the car sat for almost 2 weeks.
I started/stopped the motor about 20 times last night when testing the engine codes I was getting and the battery never skipped a beat. I'll know after a few days of normal driving if it was affected negatively. I like having the small battery in the car but the verdict is still out on whether or not the drain of the bottle heater and other factors will make it more trouble than it's worth. I need the original battery spot for my fuel cell though
Good jumper cables have one feature...they are heavy. Lots of copper is the key to carrying all that current effectively. 2 gauge is good, and they should feel heavy.
