Code P0449/P0455 and fuse 13
Old Jul 17, 2012 | 02:53 PM
C7cmnthru's Avatar
C7cmnthru
Default Code P0449/P0455 and fuse 13
I did a search and read previous posts. Just have a couple of questions. P0449 is the primary code and P0455 Evapor Emission system leak detected) is the secondary code. Both codes showed up today out of nowhere. I was just driving along. A secondary event was that my radio presets all "reset" to the same station (87.9 FM).
In any case, I wondered if anyone had this particular combination of codes and what was the ultimate fix. Also, I did look for fuse 13 but was unsure as to whether the fuse was located under the passenger floor or under the hood. It appears to be under the hood. And in my case, the 25A fuse was not blown.
Appreciate any feedback/help. BTW- 26500 miles.
Old Jul 20, 2012 | 08:32 PM
C7cmnthru's Avatar
C7cmnthru
TTT. I went ahead and replace the solenoid. Cleared code and it re-appeared. Can anyone suggest what else might be going on here?
Old Nov 19, 2012 | 08:28 PM
harley7453's Avatar
harley7453
HELLO..
Can you tell me how things worked out with your problem.how did you fix it??
thanks...
Old Nov 20, 2012 | 08:46 AM
C7cmnthru's Avatar
C7cmnthru
Sure. Ended up going to dealer. Turned out to be another solenoid in the loop. The faulty one was located near the drivers side gas tank. Cost a couple of hundred for diagnosis, part, and labor. I probably could have done it myself but didn't have the time or energy. Looked like u would have to pull the wheel and some shields.
Originally Posted by harley7453
HELLO..
thanks...
Old Nov 20, 2012 | 08:08 PM
harley7453's Avatar
harley7453
THANK YOU.....
To Code P0449/P0455 and fuse 13
