rear main seal tool
Old Jul 24, 2012 | 07:45 PM
AYello1's Avatar
AYello1
Default rear main seal tool
Whilst replacing the rear main seal on my son's '02, LS-1 Camaro we discovered that a plumbing fitting from Home Depot was a nice fit and can be used to press the new seal into place without tapping directly on the seal. Checking part numbers show that LS-1 & LS-2 use the same seal and although I didn't check for sure, LS-3 could be the same too. The fitting we used is a white, abs, 3"x4" drain pipe coupling made by NDS, Home Depot item # 52063 40407. $1.79. Who'd a thunk!
