anybodies had this problem with headlights??
Old Jul 28, 2012 | 05:07 PM
c-ohsik's Avatar
c-ohsik
Default anybodies had this problem with headlights??
Just bought c6 but headlights look like wrinkled any info on what i can do to fix them any product out there.. thanks
Old Jul 28, 2012 | 08:51 PM
ChevyDave's Avatar
ChevyDave
humm... heard of foggy, hazy, scratches, spiderwebbing, pits... but not wrinkled. some have tried to polish the lens but i have read many warnings that polishing is a very bad idea.
if they are bad enough (and your not under warrenty), there is places that sell just the lens but for about $350 a pair. You would need their instructions for removing/installing lens as they are 'glued' on, which i have also read that oven baking will soften the glue for removal. But i would never try that without proper instructions myself.
Old Jul 28, 2012 | 09:46 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
do a search on headlights here and in the General section. Lots of pics and write ups.
Old Jul 29, 2012 | 08:12 PM
Anthony s's Avatar
Anthony s
If the little cracks are one the inside, it's called crazing. It's covered under the 3 yr bumper to bumper. Not under the extended. The headlights are attached to the inside of the bumper. Each unit is ( OEM) about $1,000. eBay is about half that. Do a search on it. My dealer was nice and replaced them at 39 months. Good luck.
Old Jul 30, 2012 | 03:44 PM
JCtx's Avatar
JCtx
If really wrinkled, it could be they have 'clear bra' over them, and the installed wasn't the best. If that's your problem, it's easily remedied. Otherwis you read the options above. Good luck.
Old Jul 30, 2012 | 03:58 PM
taken19's Avatar
taken19
Track Junky
Mine also have a strange thing going on. The outer layer of plastic, let's call it the "clear coat" is beginning to peel off. Now I assume I will need the new lenses as they are showing signs of crazing as well.
RL, do you still do the lens replacement? If so, how much?
Sean
Old Jul 30, 2012 | 10:36 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
PM Sent
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
To anybodies had this problem with headlights??
