2005 Starting Problem
Old Jul 31, 2012 | 12:58 PM
shaun5142's Avatar
shaun5142
Default 2005 Starting Problem
Hi,
I'm hoping someone might be able to tell me what could be wrong with my car. Sometimes when I push the start button it does not attempt to start. The gauges come up and everything, but there is no attempt to turn over the engine. It also usually gives the "service column lock" indicator. I have read about that problem, but mine seems different. I bought my 2005 about 4 years ago and this problem 1st occurred not to long after I bought it and has gotten progressively worse. At 1st when this happened I just released the clutch, pushed it back in and on the 2nd attempt it started no problem. This would happen maybe 1 time every 3 months or so and the car is an everyday driver. Just in the past few months it has gotten a lot worse happening maybe 1 of 3 times I go to start the car and now just releasing the clutch no longer works. Now I have discovered that if I disconnect the battery terminal and leave it off for about 15 seconds before reconnecting, then it starts like there was never a problem. Any advise would be appreciated. I have asked the dealer and they say they would have to see it happen.
Thanks,
Shaun
Old Jul 31, 2012 | 01:18 PM
Hoonose's Avatar
Hoonose
Originally Posted by shaun5142
Hi,
Thanks,
Shaun
If your battery checks out OK, your column lock may be failing. (SCL).
Do a search on the forum as someone recently came out with a relatively cheap bypass for this, vs a $600-1000 repair to actually replace it.
Old Jul 31, 2012 | 01:31 PM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
you have the typical 2005 column lock problem. at sometime almost all 05 manual trans car will run into this problem. but your in luck as we just released our column lock eliminator for the 05.
instead of spending $1000+ to have a shop repair your car (using the same troubled parts) you can just delete the column lock completely.
we have had this product out for 3 weeks now and have sold over 100 units with no problems or complaints (other than gm;s connectors are confusing)
takes less than 30 mins to install ( we can do it in less than 5 mins)
we have a install video to help you as well
see one of my many threads about this unit
http://forums.corvetteforum.com/c6-c...ssues-fix.html
http://forums.corvetteforum.com/c6-p...ssues-fix.html
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old Aug 1, 2012 | 11:10 AM
shaun5142's Avatar
shaun5142
Thanks for the advise. I ordered it today and I'll let you know how it works.
Old Aug 1, 2012 | 12:25 PM
Front Runner's Avatar
Front Runner
This is a great product! So far so good for me. I installed it on my 05 (before the video came out) and all went well. I havent heard the column lock motor since!!
Old Aug 16, 2012 | 01:04 AM
shaun5142's Avatar
shaun5142
This has been a GREAT product so far. I have not had a problem since. It took me a lot longer than the video due to my inability to disconnect all the wire harnesses. I think you need hand the size of a 5 year old with the strength of a gorilla. I also noticed that all of my harness wires were a lot shorter than the wires in the video, which made it difficult to move the dash parts around - I guess somebody at GM figured out that they could save $.10 on each $50-$60K car by shortening the wires.
Thanks a lot for pointing me to this product.
To 2005 Starting Problem
