What is the easiest iPhone iPod Aux connection you can buy? I have a 09Z and hate the fact that I can't listen to my own music... please point me in the right direction. Also I have the Nav in my car, not sure if that matters. Thanks fellas.
It makes it real easy. Just look on the forum here and get the GM PAL from Ray Krawl. Its plug and play. An easy install (about an hour) if you have a convertible less if you have a coupe. Just search Krawl or GM PAL. He has the install instructions on his web page.
I recommend the USA Spec brand. I bought mine a few years ago. No complaints at all. Very easy to install if your system has XM built in. I installed the system in about 30 minutes. Model number: PA15-VETTE.
Another notable aspect of this system is that it is up-gradable so when the next iOS software comes out and your peripherals no longer are compatible you can take the module out, hook it up to your computer, and update the software.
