N/A 454 help
i want too make a big power N/A sleeper...
please, tips or improvements needed too make that horse power stuff.
would it be cheaper too buy new ones and sell mine?
and how much horse can i expect from properly matched heads, cams, cubic"(454), and compression (11 to 1).
Give each of them a call to get real world data or check out their websites. You may also want to call some local Vette specialists to see what they recommend. Some that come to mind are Horsepower Sales, Breathless Performance, Redline Motorsports and Monster Motorsports.
The engine is quite punchy as is. It idles with about 74 KPA of pressure and is a bit sensitive below 1800 rpms. A few of the Camaros we built we actually cut a new camshaft that picked up over 38 HP and 40 ft/lbs below 4500 rpms and gave up 20. Much better drivers.
That engines biggest issue is the "as cast" cylinder heads. A factory ZO6 comes with CNC'ed ports and these are just raw. Cylinder head porting is dire in that engine as its got alot of displacement and choked heads! We have a great port program with out machinest for that engine.
The stock intake is also hurting that engine and you will pickup nicely with a LSX 102mm.
We built a 2011 for GM Performance in 2011 with that engine with the toned down camshaft. GM didn't want the aftermarket intake so we built it with a stocker for its debut at the PRI show. Once the show was over we swapped to the LSX and picked up quite a bit.
GM knows the engine is piggy down below but corporate demanded an engine north of 600 crank....they didn't care about how it idled as there market was the guy with the 69 Chevelle.
Its also a very loud engine so the mufflers should be thought about properly!
Here is the info on the Camaro.
http://www.redline-motorsports.net/2...play-pri-2010/
Please let us know if we can be off assistance as we know that powerplant well.
Howard
HT
Z06SlapMopar, Howard's (Redline Motorsports) shop is top notch! You can eat off the floors. He does very high end builds, several have been featured in magazines. Give him a call and speak to Howard or Jay, they will give you a true idea of the potential that motor has.
Below is the graph showing the stock baseline vs. the LSX 454 with our 1C cam, CAI, shorty headers and stock cats.
Most people would look and think it was a stock engine with a CAI
The heads could definitely benefit from porting and we do have a CNC program for them.
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
Also do you have any cams that drive like crap but hall-***.
i would like make roughly 600rwhp if possable?
or is it possable to put this motor on boost?
The compression is high for boost, but 600 RWHP N/A shouldn't be an issue. Is the car an auto or manual? We make 600+ RWHP with head/cam bolt on stock bottom end Z06's, so with the added displacement of this engine, ported heads and a large cam it should be no problem.
Thank you,
Rick
Thank you
Regards,
Rick LeBlanc
Our car is an Auto, and it has an L99 in it, not an ls3 from the factory. Typical baseline's on the L99 Camaro is 325-345.
(954) 984-8040
1490 S. Dixie Hwy East
Pompano Beach FL 33060
United States
You are very kind. We appreiciate you as well.
Well, we certainly are in esteemed LSx company here within this thread, along with Rick of Livernois, and Howard at Redline. Top notch.
Great advice from all Nick, and we also will throw our hat in the ring again.
As we remember it, no addl. expenditure was available at the time to work on your existing Cylinder Heads.
Please call me, and then come on by for a one on one with Jeremy, for
Headwork, and power output idea's on your 454 LSx.
We have the experience to make you happy, and the service and outcome to continually earn your business.
We'll have a good thought for you and Dad. You are Great Guys and Customers.
Rick @ HPS of Pompano, Fla.
